- « Previous
- 1
- 2
- Next »
Re: Twitter
22-07-2015 4:56 PM
Quote from: HarryB I wouldn't worry about that too much, as long as you're connected via cabled connection it should be fine.
Hi Harry,
To be a pedant, if a device has both a wired and wifi network interface and both are active, there can be no assurance which network route the speed test will use. There have been a number of incidents where a user has plugged a wire into a PC otherwise using wifi and results have appeared to be the same.... until the wifi NIC has been disabled. I suggest that at best this advice is optimistic.
Quote from: Matthew I suspect it could be a old issue with the TG585's.
@Estragon,
This might be risky advice... depends on the user's ability / confidence.
Re: Twitter
22-07-2015 6:42 PM
Re: Twitter
22-07-2015 8:23 PM
But you are absolutely right about turning off the wireless on the device doing the wired speed test. Not just when doing speed tests either - I generally find that if wifi is connected then Ethernet is added, the connection stays on the wifi.
Re: Twitter
22-07-2015 10:08 PM
In device manager (see attached screenshot) there are three possible candidates for switching off the wireless on the PC
Re: Twitter
22-07-2015 10:18 PM
Re: Twitter
22-07-2015 10:29 PM
Thanks - must change my opticians...
Re: Twitter
22-07-2015 10:34 PM
Re: Twitter
22-07-2015 10:36 PM
Re: Twitter
23-07-2015 4:39 PM
I will post if there is any more news
- « Previous
- 1
- 2
- Next »
