Training Period
- Re: Training Period
Training Period
24-02-2014 1:55 PM
Could a Plusnet staff member confirm that the training period on my line is now complete? Will rebooting my router occasionally have an impact on my speeds?
BTW speed test shows:
Download speedachieved during the test was - 17.1 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 18 Mbps
I am happy with my speeds but was wondering if there is anything I could do to get closer to IP Profile for my line - 18 Mbps
Message 1 of 5
(759 Views)
4 REPLIES 4
Re: Training Period
24-02-2014 2:01 PM
Your line is now out of the training period.
If you frequently reboot your router, the exchange equipment will think your line is dropping out and will band the lien which will result in lower speeds as explained here http://community.plus.net/library/broadband/broadband-faults-guide-banding-guide/ .
Your speeds are very good, I wouldn't expect to achieve much more from your line in my opinion.
Message 2 of 5
(478 Views)
Re: Training Period
24-02-2014 2:10 PM
Thanks for the reply, So the odd reboot will not have an impact. ie if I switch off the router if I am away for the weekend etc?
Message 3 of 5
(478 Views)
Re: Training Period
24-02-2014 2:12 PM
That's right, that should be fine.
If you're rebooting a couple of times a day, that's when you start to see problems.
Message 4 of 5
(478 Views)
Re: Training Period
24-02-2014 2:15 PM
If you are only switching the router off 1 or 2 times a week then that will be fine
Depending on the time of day you switch you router back on you may decrease or increase speed slightly which is normal
For example to get the best sync for my area I have to switch on or reboot the router between 09:30 AM & 10;30 AM when all neighbors are out or in work
Message 5 of 5
(478 Views)
