Router buzzin and slow responses?
jasonfreeman
My technicolor TG582n router has started to buzz when I restart it and when the buzzin stops its slow to respond than usual?
jasonfreeman
Re: Router buzzin and slow responses?
I know that isn't normal and I've plugged it in another plug socket and I've used the original power supply plug that was supplied with the router
Fixes: 10
Is it less than a year old?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jasonfreeman
Yer I've only had it about 3 or 4 months
Fixes: 10
Have you commented about it on your fault ticket? If not I suggest you do so.
Less than a year old it should be replaced for free.
Plusnet Staff
Plusnet Staff
Fixes: 5
I can't see a router component on your account.
Did we send you one upon signing up with us?
Chris Pettitt
Cloud Environments Engineer
jasonfreeman
I ment I am still using the original plug for the router
Fixes: 62
where did you get the router from as Plusnet don't seem to have a record of supplying one to you
jasonfreeman
They supplied it to me as a replacement 3 or 4 months ago
jasonfreeman
Have they found the record of the router being sent to me?
TORPC
Give em chance,
It's only been less than an hour, since you updated them Wink
Fixes: 62
Plusnet Staff
Plusnet Staff
Fixes: 5
I've updated your ticket. Hopefully that should resolve the problem for you.
Chris Pettitt
jasonfreeman
Ok thank you chris
