Throttling?
PantherEins
Throttling?
Is it possible that Openreach are throttling a connection?  Currently running at 49mbs and have been statically for months and months with the dead same upload speed of 11.69 when advertised is 53-70, 13-20 and when I started the renewed contract i was on 70!
5 REPLIES 5
PantherEins
Re: Throttling?
Hmmm, another line fault?  Had OR out twice for 4 different faults.  Given I'm 200m from the Cab it's frustrating to say the least.
Fixes: 382
Re: Throttling?
@PantherEins  It would be helpful to those of us who try to help if you provided the information requested below - ignore the item you have posted above.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
pvmb
Aspiring Champion
Fixes: 15
Re: Throttling?
Unfortunately, BTW Performance Tester -  'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected - no longer seems to work for many people.
Summary Advanced Test
"Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information."
It worked when I was on ADSL2+, did it ever work on FTTC? I don't recall it doing so.
Fixes: 382
Re: Throttling?
@pvmb I am aware that the 'Advanced Diagnostics' appears to be 'broken' for most. However, it does occasionally work, which is helpful. If it doesn't however, combined with the other data  requested, the initial test is useful.
Fixes: 476
Re: Throttling?
@PantherEins
The only time that Openreach ‘throttle’ a connection is if after a reset there are two many errors on the line and data is having to be resent too many times. This is an automatic DLM action designed to increase the useable data that you receive.
It is unusual for your service to be reset due to a contact renewal but could result from a change, for example, a move to SOGEA.
I don’t know if it’s relevant but in the early 1970s the GPO, as it was then, used aluminium cored cable rather than copper for some installations. This has always been troublesome.’
Either way, your speed is below the handback threshold so you should report a fault.
