Thomson Router stable connection but poor wireless network
- Re: Thomson Router stable connection but poor wire...
10-07-2011 1:47 AM
My other routers suffered none of these network problems but, as I mentioned earlier, they would lock up daily, requiring a complete reboot. The download speeds used to fluctuate wildly as well. Using the Plusnet supplied Thomson router the speed is a steady 13mb.
Does anyone have any tips for getting a functional wireless network from the Thomson TG585 v8?
Thanks.
Gordon
Re: Thomson Router stable connection but poor wireless network
10-07-2011 2:04 AM
10-07-2011 2:19 AM
10-07-2011 8:22 AM
Quote from: GordonWT Does anyone have any tips for getting a functional wireless network from the Thomson TG585 v8?
Make sure it is running the latest firmware, 8.2.7.8, and if not go here http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7... (which also covers the v8 router despite, the page title).
10-07-2011 9:56 AM
That way you can -
1- Keep you stable broadband router.
2- Choose a WAP with better dedicated performance than the integrated wireless of the router.
3- Site the router near the master phone socket for best ADSL performance, and mount the WAP where it will give best wireless coverage.
4- You could switch off the Thomson's wireless if the WAP gives sufficient coverage.
5- You could leave the Thomson wireless on, and also have the WAP set to the same SSID but on a different channel, which may give you better coverage than just one device.
10-07-2011 5:17 PM
Some devicesdon'tt get on with channel 12 or 13 which could be an issue. The non-overlapping ones are 1, 6 and 11 although if they are really busy (by using the iPhone tools) 3 or 9 should get you a clear enough signal.
If your not happy with messing around with the wifi channel I'm sure the CSC can talk you through it.
11-07-2011 8:24 AM
Have you tried buying a router that cost around £100 ? Try something like a Draytek I can recommend Draytek 2710n model I get no dropped connections and my download speeds about 7.5mg and a sync at a constant sync 8128.
In addition you can connect a usb printer and /or usb hard drive for a network type setup. Some models in the 2710 range can run a dect phones and there also a VoIP model too. The wireless speeds 300mbps unlike the Speedtouch which push out only 54mbps but make sure your wireless cards is n compatible first. In my dining room my speedtouch gave me problems I only got 1 bar signal but with my draytek I get 4 bars now which is a great improvement
Some say the BiPAC 7800n router works well but I had problems with my ip camera login screen it kept bring up the router login screen instead.
Puddy
11-07-2011 8:58 AM
Your router has the older version of the firmware. I can upgrade it from here for you but it'll be offline for about 10 minutes while it processes. Let me know when it's convenient for you and I'll get it done. Once it's upgraded you'll find that you no longer have connectivity issues with your devices.
Jojo
12-07-2011 3:12 AM
I would be grateful if you could update my router for me. I tried (and failed) to do this myself
Anytime between 9am and 1pm would be fine if I don't have to be there (I will be at work!!).
If I do have to be there then I am usually home for lunch at 1:15pm.
Cheers
Gordon
12-07-2011 1:03 PM
Just doing that now, so should be complete in the next 10 mins.
Jojo
12-07-2011 1:23 PM
12-07-2011 1:36 PM
The update is complete and is now showing 8.2.7.8
Fingers crossed it cures my wireless probs!!
I will let you know how I get on.
Cheers
Gordon
12-07-2011 3:13 PM
13-07-2011 1:46 PM
The printer is no longer invisible and my Squeezebox updated itself and got back on the network without me having to reboot the router.
Thanks to all for advice
Gordon
13-07-2011 1:49 PM
