Technical log
stalked26
Technical log
Hello
Does anyone know why entries would be missing from a technical log?
A quick internet search suggests it's not possible to delete entries from a technical log but on the day in question there are no entries listed between 04.01 and 23.55. There definitely should be entries on that day, and they could possibly be incriminating (against someone who is stalking me) so I need to get to the bottom of this.
Many thanks
2 REPLIES 2
Fixes: 374
Re: Technical log
@stalked26 It would possibly help if you could post the exported log - the full one, not just the day in question.
stalked26
Re: Technical log
Hi @jab1
Thank you for your reply. I appreciate the help. I've downloaded the log and attached it. The date in question is July 8th.
Thank you.
