TG585 v8 firmware upgrade failed
- Re: TG585 v8 firmware upgrade failed
- « Previous
- 1
- 2
- Next »
17-09-2013 11:27 AM
I can see you've got a few responses with some suggestions to try, keep us updated.
Message 16 of 23
(840 Views)
17-09-2013 7:16 PM
The router stopped working so I rang up and a replacement is on its way. If its not on the new firmware when I get it, I will reflash the new one when it comes and see how that goes. I will let you know here.
Message 17 of 23
(840 Views)
17-09-2013 7:39 PM
Are they sending you another TG585v8 or a TG582n (ADSL2) - the current offering?
David
Message 18 of 23
(840 Views)
17-09-2013 8:18 PM
They didnt say which but I suspect its a tg582n, my old one of 3 years is a tg585 v8
Message 19 of 23
(840 Views)
18-09-2013 9:41 AM
It will be the Tg582n, let us know how you get on with it.
Message 20 of 23
(840 Views)
19-09-2013 11:52 PM
Got new router today, I tried the 10.2.0.B firmware without realising it was ADSL firmware, but I added the ewan port myself so I now have this: http://i1333.photobucket.com/albums/w639/lotrjw/routerscreenshots19-09-201323-28_zpsc5984691.png result!
I can now use both interfaces ADSL and ewan PPPoE! and it tried them both at the same time! lol if only I had two lines to check it with! I wonder if plusnet would like be to test that! I would need a second phone line though and I couldnt afford that myself!
Message 21 of 23
(840 Views)
20-09-2013 12:42 PM
glad you've got that working, a tweak has been made to the firmware so both PPPoA and PPPoE connections will work.
Not sure about the free line, good try though
Message 22 of 23
(840 Views)
20-09-2013 2:30 PM
Shame about no free second phone line for testing, but at least I now have a working router (and a working wifi on my w8 phone! but that was solved by something else not the new router!)
Message 23 of 23
(840 Views)
- « Previous
- 1
- 2
- Next »
