TG585 v7 reboots
- Re: TG585 v7 reboots
12-07-2009 9:11 PM
Quote from: mal0z The summer time still keeps switching off in the "beta" test version of 7.4.4.7
Poo
It makes it awkward when I'm reading the event logs as I have to remember that all the times are wrong by an hour.
12-07-2009 9:15 PM
M
07-08-2009 11:30 AM
Cheers
David
07-08-2009 11:35 AM
There are other giveaways; generally the data amounts in the connections details will be reset for a kernel warm restart, but won't for a plane old ADSL disconnection.
07-08-2009 6:32 PM
Anyone any ideas on how to enable logging for other categories, as perviously mentioned I only seem to see firewall stuff at the moment.,
Bob, I'd also be happy to try out the new firmware
Cheers
Dave
07-08-2009 9:19 PM
You could try disabling one or both of uPnP and the wifi.
(So far I have the new firmware and have disabled uPnp, and still get the resets - the wifi is the next to be disabled...)
07-08-2009 9:25 PM
Wonderful!
07-08-2009 9:48 PM
08-08-2009 12:37 PM
Any progress on this? I have reboots on my Thomson TG585 v7 several times each day, usually at the most unfotunate moments, it seems. Did the newer firmware that Bob mentioned fix this? I would be happy to try the new firmware if it is still available.
Thanks.
-Jon
08-08-2009 3:17 PM
hey guys i think i may have found a fix for the time on this router as i too was not keeping with summer time however after setting the settings to manual and clicking summer time to on it has kept the setting,hope this may help you.
Quote from: SteveA Does the Beta fix the fact that Summer time keeps getting turned off on router if you tell it to use PlusNets time server, which of course means that as the PN time server thinks its 6:44 GMT all the times in the router are off by one hour
08-08-2009 4:33 PM
08-08-2009 4:49 PM
Time Configuration
Time Source: Manual
Timezone: (UTC) GMT: Dublin, Edinburgh, London
Summer Time: Yes
ok it seems ive made a booby of my router time settings never mind a fix!! back to the drawing board
10-11-2009 10:19 AM
11-11-2009 5:59 PM
Stuart
11-11-2009 6:09 PM
