TG585 v7 reboots
TG585 v7 reboots
Anyone know what causes the TG585 to do "kernel warm restarts"?
Mine seems to have decided to start doing these quite frequently, and of course if it does it during the day it connects at a higher speed than it can maintain when it goes dark and then I get 100s of thousands  of FEC errors.
James
Re: TG585 v7 reboots
Hi Steve,
I believe that this is a known issue which Thomson are fixing for the next firmware update.  I'll ask Bob to confirm in a bit as he's been dealing with Thomson.
Fixes: 70
It has been cited as an issue with the 7.4.4.7 firmware in the past - is that the version you're using Steve? If so, would it help if I was to forward you some updated firmware?
Plusnet Products Team
Bob, yes I'm on the 7.4.4.7 firmware and I'm happy to try upgrading it to a later revision.
Fixes: 70
I've dropped you a PM Steve.
pierre_pierre
is there anything specific about 7.4.4.7 as that is what I have, the netmeter shows a lot of traffic to the router that I didnt get on the old 2110 that I have, but it has currently been up for 25+ days, no drop of line
The Easy Start TG585 router that I have just received from PN has 7.4.4.7.
But I'm not going to change it as it's part of the trial.
Not sure what the original TG585 has.
mattgrimley
Hey Bob,
I appear to be having the same issues with my router constantly rebooting. It's a Thompson TG585 v7 Firmware: 7.4.4.7.
If this is something addressed by a firmware update, could i get a copy of that also? Are the firmware updates published anywhere or do you have to "ask" for them?
I have been trying to get to the bottom of my naff connection for quite some time now.. Seems a tad frustrating that it would be a known issue..
Matt
If you're suffering from reboots, and are unable to upgrade to the latest firmware, try turning off UPNP on the router.
B.
mattgrimley
Thanks for the comment Barry, but i have a Thompson Router supplied by PlusNet, so if there is an updated firmware to fix the issue, i really need that.  Looking at the Thompson website they only seem to be offering the 7.4.4.7 firmware for download. Of course it wouldnt have been that simple anyway, as i have the "Plusnetted" version on my current router.
unless i am mistaken, this thread seems to suggest a newer firmware is out there, which makes troubleshooting the exact same issue (by disabling UPnP) a bit pointless for now.
Matt
Quote from: Barry
B.
And does the Beta firmware fix that problem?
Fixes: 9
As far as I know there is no 'general release' version of the firmware later than 7.4.4.7.  A small number of PUG and Community members are testing a slightly modified version as part of some trials, but there are still some issues yet to be resolved.
The Reboot problem was reported some time back, but I do not believe a 'fix' is yet in the firmware version we are testing.  As Barry suggests, switching off UPNP did seem to alleviate the problem for the User reporting it.  Worth a try.
Maurice
PS If I go away for a while its because I'm just about to reflash the Router for another of the tests Grin
Does the Beta fix the fact that Summer time keeps getting turned off on router if you tell it to use PlusNets time server, which of course means that as the PN time server thinks its 6:44 GMT all the times in the router are off by one hour
MrC
Quote from: MauriceC
When I was trying out a TG585v7 I found (and loaded) a generic 8.2.3.7 firmware. Can't really tell you whether it fixes any known issues as the router is currently living in it's box Smiley Seemed to work OK though.
Mike
@SteveA
The summer  time still keeps switching off in the "beta" test version of 7.4.4.7  Sad
