TG582N Firmware
- Re: TG582N Firmware
TG582N Firmware
29-03-2013 6:04 PM
I need to flash my firmware on my TG582N, Plusnet support have suggested Techniclour's website, they no longer supper end users and have told me to contact my ISP.
My ISP of course have their own version of firmware and I need the factory standard one.
I need to change my IP from 192.168.1.254 to something else but Plusnet have locked this down.
So does anyone know where I can find the firmware and how to flash please?
Message 1 of 6
(1,306 Views)
5 REPLIES 5
Re: TG582N Firmware
29-03-2013 6:32 PM
Quote from: uktotty
Are you talking about the plusnet firmware?
If so it's not locked to 192.168.1.254, to check I've just changed mine to 192.168.1.2.
To change it in the routers GUI, go here:
http://192.168.1.254/cgi/b/intfs/_intf_/cfg/?be=0&l0=4&l1=1&name=LocalNetwork
Use "Edit" to change 192.168.1.254 to any valid address.
Message 2 of 6
(525 Views)
Re: TG582N Firmware
29-03-2013 7:19 PM
Interesting!
I tried to change mine to 192.168.2.254 but it woudln't work.
Called plusnet tech and they told me it wasn't possible due to their firmware.
My office LAN is in 192.168.1.x and I need a different IP address range.
I haven't tried too change it to 192.168.1.2 as I need to move away from that range,
Message 3 of 6
(525 Views)
Re: TG582N Firmware
29-03-2013 7:26 PM
Message 4 of 6
(525 Views)
Re: TG582N Firmware
30-03-2013 11:54 AM
You sir are a genius!
Thanks very much, kudos!
jim:quote
jim:quote
Message 5 of 6
(525 Views)
Re: TG582N Firmware
30-03-2013 1:20 PM
Quote from: uktotty I tried to change mine......
Well as you've discovered, that is complete rubbish. There is plenty more information on this forum about the 582n firmware and changing settings etc. Just do a search. If you are stuck, just post.
Edit: Oh, I recommend you go off-line first before making changes, drop your PPP session, then power down. Stay off-line until you've finished, so any reset's reboots etc don't give the exchange DLM the idea you have a dropping connection. When you go back on-line, click Connect to start a new PPP session.
Message 6 of 6
(525 Views)
