TD-W8968 N USB ADSl2+ Router set -up
- Re: TD-W8968 N USB ADSl2+ Router set -up
01-11-2014 5:33 PM
Anyone out there that has successfully tramped through the process and got connected?
I am back on the Belkin and all is well as can be expected!!
02-11-2014 2:29 PM
02-11-2014 3:11 PM
If it's the V3 http://www.tp-link.com/resources/document/TD-W8968_V3_QIG_7106504628.pdf
03-11-2014 1:29 PM
That Quick Set Up Wizard is supplied on paper with the router and goes through the procedure and seems to tick the boxes OK until the final check when it fails to verify the router settings. All the lights do seem to show a good result but no connection results. I will have another go at some of the items dealing with Plusnet where the built-in details do not quite agree with the data available from PN. Particularly multiplexing was shown as VC and PN says VC based/VC MUX/VC-multiplexing and I typed it in full.
I am a bit busy on other matters but will try again.
As I put in the post, the full user data is so complex that I could not really wade through it. Hopefully things will be overcome. Do you have any experiences with the new router? I am not sure that it is covered in RSL I am on version 9.9 right now.
03-11-2014 1:39 PM
03-11-2014 3:11 PM
03-11-2014 3:33 PM
03-11-2014 3:42 PM
edit lost URL digit!
03-11-2014 3:50 PM
03-11-2014 3:51 PM
According to what I've just read, it's 192.168.1.1
03-11-2014 5:08 PM
The login to this router is tplinkmodem .net. I don't think RSL will work on this model. I did have it working on the TP-Link 8960N, the one that is in the RSL list of routers.
It does say something about if the login is embedded in a webpage RSL wont work. I could be completely wrong here but I read this on the website for RSL.
Please note that the router MUST pop up a login authentication dialogue similar to one of those shown on the right. RouterStats -Lite will not work with routers which use a login embedded in a router webpage.
Ron
on 03-11-2014 6:01 PM - last edited on 27-04-2016 4:05 PM by bobpullen
Hi Ron, funnily enough I had just been reading your thread (2 posts), where you had posted the full xDSL: stats twice and no-one had responded
I was talking with Colin and we were trying to find the page where stats were, as the manual is rather bulky for Colin to work through.
Anyway, having found your post we were able to find the info.
Thanks for reminding me about the login, because that may be the crux of getting this sorted, as you say I'm not sure it works with RSL either.
I'll go and remind myself, as I haven't done a customised setup for a while which was the avenue being explored.
I hope all your line problems got resolved.
03-11-2014 7:14 PM
The problems I had seem to have been resolved after the last BT visit, the connection has been up for over 18 days now and is more stable on a 6db SNRM.
I did try to set up RSL on the TP-Link 8968 with a customised setup but it was a bit too technical for me so I gave up, I might have another try, but the bit about the login being embedded in a webpage made me think again.
Ron
03-11-2014 11:29 PM
04-11-2014 11:43 AM
I am sorry that SWMBO was getting a bit fractious and terminated our lengthy discussion last night. I have not had time to delve into RSL webpage today to see if there is any further guidance from the author yet. The stats look unchanged overnight.
Fifer looks like a useful joiner in this matter.
