Laptop Hitting Internet Offline
ruth
We have a new laptop (Samsung Series 7 Gamer) which keeps hitting the internet offline when connected wirelessly. However, there is no issue connecting wirelessly at someone else's house or if i connect using an ethernet cable. We have other computers and phones that connect to the internet fine and have had no issues. I have tried installing the latest firmware onto the router (ThompsonTG585 vCool with no change to the issue. I have also tried downloading the wireless drivers off the Samsung Laptops website which again has not made a difference.
Fixes: 16
Re: Laptop Hitting Internet Offline
See https://community.plus.net/library/hardware/fixing-wireless-compatibility-problems-with-the-thomson-...
(not that you should have to change settings on the laptop to work around bugs in the 585v8, but there are no other solutions)
ruth
Thank you very much! We were close to selling the laptop, but this has done the Job!
Plusnet Staff
Plusnet Staff
Fixes: 159
Good to see that ejs gave you a link to fix this issue, I'll remember that for future reference.
 Chris Parr
 Plusnet Staff
