Sync at 77Mb but DL speed is only 36Mb Max
- Re: Sync at 77Mb but DL speed is only 36Mb Max
24-01-2013 9:10 PM
I am connected directly to the the router via cat5e cable, so it's not a wireless issue.
24-01-2013 9:33 PM
Alex
24-01-2013 9:44 PM
24-01-2013 10:51 PM
adie:quote
24-01-2013 10:55 PM
Hopefully we can get that sorted for you by Monday
24-01-2013 11:06 PM
adie:quote
24-01-2013 11:08 PM
24-01-2013 11:37 PM
adie:quote
25-01-2013 7:22 AM
Quote Cheers, any idea when it will be fixed?
[quote=Chris Parr]We'll get this corrected for you and you should be up to full speed on Monday.
25-01-2013 9:31 AM
Under connection settings > High-Seed Broadband
Telephone number:
xxxxxxxxxxx
Phone exchange:
xxxxxxxxxxx
Estimated line speed:
65Mb (Accurate to within +/- 1Mbit) - Checked on 2013-01-18 01:28:40
Current line speed:
78 Mb
25-01-2013 9:54 AM
Run the BT speed test - diagnostic second stage - this explains http://community.plus.net/forum/index.php/topic,96155.0.html
25-01-2013 1:26 PM
I've checked to order to place you onto the correct product and it's not due to complete until Monday, sorry for the delay with this.
Let me know on Monday how your speeds are.
30-01-2013 10:13 PM
Quote Download Speed
54.25 Mbps
77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 54.25 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload Speed
16 Mbps
20 Mbps
Upload speed achieved during the test was - 16Mbps
Where has my speed gone?
dick:quote
31-01-2013 9:31 PM
my DL speeds are still down around the 55Mbps mark which is way off the quoted line test speed and even further below the actual line speed.
It's nothing to do with my network either as I have done some file transfer tests with no problems.
01-02-2013 9:51 AM
Quote from: liquidphantom i'm not sure why my last post was edited.
Did you read the link in the note added by the moderator?
