Suddenly sloooowing down problem.
- Re: Suddenly sloooowing down problem.
26-11-2007 9:10 PM
Heres my speed test results... Getting 16k/s on a download that I was getting 174k/s. Not touched anything.
Any ideas?
26-11-2007 21:07:10 675.8
26-11-2007 20:36:18 773.3
26-11-2007 08:14:43 1383.5
21-11-2007 22:58:21 1427.2
21-11-2007 08:47:32 133.3
21-11-2007 08:44:54 136.9
Any ideas?
Message 1 of 7
(2,100 Views)
6 REPLIES 6
26-11-2007 9:50 PM
Since above post....
Rebooted puter... turned off router for 5 mins... Reconnected router... turned on puter.
Started download and watched connection go from a steady 150k/s to a very unsteady 20k/s. Connection seemed to be on and off.
Got 82% showing on wireless connection, but even that just drops instantly and then pops back with the usual 82%.
Havn't got a long enough cable to try the direct approach, but puter is only 6 foot at the most from router.
Are PN having any troubles!!! Thought I'de better check before tearing puter apart and rebuiling from the case up.
Message 2 of 7
(815 Views)
27-11-2007 1:30 AM
You've got a very small network cable if it won't reach the 6 foot to your router Rick!
Considering your router is so close and you state that the signal drops badly, I can't honestly understand why you don't invest in a cable long enough. After all they are only a few quid m8, and you would almost certainly get better results than wireless.
Message 3 of 7
(815 Views)
27-11-2007 9:34 AM
my cable would have to be about 15-20 foot to account for the shape and direction. Would a cable this long work?
If I can get one long enough I will try it.
Message 4 of 7
(815 Views)
27-11-2007 9:42 AM
Hi Rick,
Before I moved house, I used to have my router connected to my computer by a piece of 50 foot CAT5e cable. there should be any issue with the kind of length that you're referrring to.
Message 5 of 7
(815 Views)
27-11-2007 9:46 AM
Make sure the cable is CAT5e not plain CAT5.
Message 6 of 7
(815 Views)
27-11-2007 3:53 PM
Thanks for advice... Will get a cable this week.
Message 7 of 7
(815 Views)
