Speed has dropped off
sparkymarky1981
Since renewing my contract last month I've noticed my speed drop off quite abit, moved everything about and done the troubleshooting and speed is still terrible, even on Ethernet connection to fire stick is terrible, done a speed test on Ethernet and only reaching 2.8 m/b, it's like being back on dial up everything buffers.
17 REPLIES 17
Fixes: 383
Re: Speed has dropped off
@sparkymarky1981 Welcome to the forums.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
sparkymarky1981
Thanks for the reply John, unfortunately I don't have a corded phone in the house, I only use the outlet for broadband.
Fixes: 383
Do you have a handset for the phone line, or are you mobile only? If so, then there is another avenue we can explore - slightly longer, but still effective.
sparkymarky1981
Mobile only household
Fixes: 383
OK. Give me five minutes, and I'll post the alternative route. A cheap handset is useful whilst you are on ADSL/FTTC though.
Fixes: 383
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
adamwalker
Fixes: 223
Hi @sparkymarky1981
I've just been running some tests that have picked up on a line fault (high resistance cable fault) so we'd need to send out an Openreach engineer to get that sorted out for you.
Let me know when you can be available in one of these slots and I'll get it booked in for you:
Monday to Friday
AM = 08:00 to 13:00
PM = 13:00 to 18:00
Adam
 Adam Walker
Fixes: 383
@sparkymarky1981 Based on @adamwalker 's post above, ignore  my suggestion above his - for the moment.
sparkymarky1981
Hi Adam,
When would an engineer be available please as I work shifts.
Mark
adamwalker
Fixes: 223
Hi Mark, it's just the slot times I mentioned in my last reply. I know it can be a pain to take time off work for these things but anyone over the age of 18 can be there to let the engineer in if that helps your situation at all?
 Adam Walker
sparkymarky1981
Ok no problem
Anyday is ok and I'll go for the later pm time slot please.
adamwalker
Fixes: 223
Cheers, I've got that booked in for tomorrow afternoon (1pm to 6pm)
I'll check back on the notes when I'm back on shift on Saturday in case we need to follow anything up with you but they should get it sorted out for us.
 Adam Walker
sparkymarky1981
That's great thank you so much
adamwalker
Fixes: 223
No worries! Smiley
 Adam Walker
