Dropping connection
siri1515
Dropping connection
Hi, the internet connection is getting lost intermittently from today morning. Can this be fixed please. We are at  [Removed]
Moderators Note: Personal information removed
Tags (1)
4 REPLIES 4
Fixes: 387
Re: Dropping connection
@siri1515 First, please delete personal information. Second, what exactly are the symptoms?
siri1515
Hi, The internet just disconnects and comes back after a 2 or 3 minutes. Thanks
Fixes: 387
OK. First , check your phone line - dial 17070, select option 2. After confirmation of your phone number, the line should be silent apart fro the regular 'Quiet Line Test' message. If there is an other noise, report a PHONE fault via: https://www.plus.net/help/report-a-problem/phone/ If that is clear, come back for further guidance.
adamwalker
Fixes: 223
@siri1515 I've sent you a PM, please get back to me when you can and I'll get this sorted for you.
 Adam Walker
