Speed drop after moving to Plusnet from Sky
- Re: Speed drop after moving to Plusnet from Sky
23-01-2015 5:51 PM
23-01-2015 5:53 PM
That seems a very small number of houses fed from one cabinet and may well make the upgrade to fibre doubtful.
23-01-2015 5:58 PM
23-01-2015 6:00 PM
From the EU State Aid Funding viewpoint, it will meet all the criteria to get NGA - poor speeds already (no existing superfast broadband)/no commercial plans for superfast broadband in the next 3 years.
23-01-2015 6:05 PM
24-01-2015 11:12 AM
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 00:00:46
Downstream: 2.43 Mbps
Upstream: 443.9 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.3 Annex A
Latency type: Fast
Noise margin (Down/Up): 6.3 dB / 13.9 dB
Line attenuation (Down/Up): 61.6 dB / 38.0 dB
Output power (Down/Up): 17.0 dBm / 12.6 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 0 / 53
24-01-2015 11:59 AM
24-01-2015 12:18 PM
ADSL Line Status
Connection time: 0 days, 01:07:03
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up): 6.2 dB / 13.8 dB
CRC Events (Down/Up): 41 / 54
24-01-2015 12:56 PM
Otherwise this could just be a case of Sky having their own slightly better equipment at the exchange, and "no compromise in service" was referring to the customer service from Plusnet's UK based call centre staff.
24-01-2015 12:59 PM
24-01-2015 1:48 PM
24-01-2015 1:56 PM
24-01-2015 10:19 PM
24-01-2015 10:28 PM
25-01-2015 3:05 AM
Just over a year ago I was with O2 and getting as high as 11.6 mbps.
Then Sky took over O2 and download dropped to around 10.5 mbps.
A couple of months ago I switched back to Plusnet (was with Plusnet between 2003 to 2010) hoping that perhaps the speed might recover a bit...
...sadly, no such luck - with Plusnet the download speed is generally around 9.5 mbps.
As far as I can remember, I believe all three providers use(d) the same SNR margin target (down) of 6dB (I don't know whether there may be other differences such as interleaving etc).
Since the only difference(s) are all back at the exchange, I'd have to conclude that both O2 (Be) and Sky's equipment is superior/less noisy in some way than BT's (Plusnet's) kit.
[Note: I'm using exactly the same modem-router etc, in all three cases.]
Now, whilst 9.5 mbps is still pretty good for my needs, and I 'respect' Plusnet - nevertheless when my 12 months contact is nearing its end I shall be giving some consideration to switching back to Sky, especially if their prices/offers are as good as they currently are (i.e. free unlimited BB for 12 month, and only 7.50 a month thereafter, and they don't fleece you for an extra £11.88 a year just for having 'caller display' [as Plusnet do] as it's included for free, as it really should be for any modern telephone service).
[Seriously Plusnet - stop charging for 'caller display' - in this day an age it's quite ridiculous, and nothing but a cynical rip-off.]
