Speed drop after moving to Plusnet from Sky
- Speed drop after moving to Plusnet from Sky
Re: Speed drop after moving to Plusnet from Sky
23-01-2015 4:03 PM
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 2 days, 00:56:48
Downstream: 2.461 Mbps
Upstream: 443.9 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.3 Annex A
Latency type: Fast
Noise margin (Down/Up): 6.1 dB / 14.3 dB
Line attenuation (Down/Up): 61.6 dB / 38.0 dB
Output power (Down/Up): 17.1 dBm / 12.7 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 24 / 56
23-01-2015 4:04 PM
23-01-2015 4:04 PM
23-01-2015 4:12 PM
ADSL Line Status
Connection time: 0 days, 00:02:51
Downstream: 2.648 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up): 6.0 dB / 12.2 dB
Line attenuation (Down/Up): 60.1 dB / 38.0 dB
Output power (Down/Up): 17.2 dBm / 12.6 dBm
CRC Events (Down/Up): 2 / 46
23-01-2015 4:19 PM
23-01-2015 4:22 PM
I would have thought it unlikely given your attenuation
23-01-2015 4:23 PM
23-01-2015 4:25 PM
My suggestion now would be to leave everything connected as it, and during daylight hours tomorrow log in to the router, hit disconnect, reboot the router and then log back in and connect. During daylight means there is likely to be less electrical interference as streetlights etc aren't on.
On Monday, assuming everything is still stable I'll get an order through to uncap your upload speed -these orders complete next working day. Normally I'd do that straight away but I don't want to make too many changes at once.
23-01-2015 4:27 PM
23-01-2015 4:28 PM
Quote from: AndyH I had a quick look at the fibre rollout for your area. Your not part of BT's commercial development, but you are part of Telford & Wrekin's superfast rollout plans. I would assume that BT will get the contract and if they do, you're expected to get FTTC with a big improvement (most properties on that cabinet are showing an expected x62.42 speed increase over ADSL).
Where did you find this information because the council seem to be very secretive about their roll-out plans.
23-01-2015 4:46 PM
The cabinet information is from BT.
23-01-2015 4:49 PM
23-01-2015 5:28 PM
It looks like Telford pulled out of BDUK to fund superfast broadband, which delayed the rollout. Although they say in their latest consultation document that they're now hopeful for the rollout to begin in the Spring.
They should be able to discuss with you when your cabinet will get fibre once the tendering process has finished. They have published a list of postcode on their website showing whether you'll be part of the rollout/not part/already have superfast broadband.
23-01-2015 5:45 PM
23-01-2015 5:50 PM
The positive thing about your cabinet is that it must be very close to you, which means when it's FTTC enabled you should get a major speed boost.
