Speed Issues
Fixes: 392
Re: Speed Issues
@Dan_the_Van I would concur wholeheartedly with your attenuation comment - unless the line length is physically changed, those values should remain fairly constant.
Re: Speed Issues
@jab1
I was going to add there is like a high resistant joint somewhere, if not already I would connect the Hub directly to the master socket as internal wiring can also cause issue with the line attenuation.
Fixes: 392
Re: Speed Issues
Good call on the MS, @Dan_the_Van , although looking at the DSL  figures in the logs, I'm still inclined to be suspecting the OR external network. I could be wrong.
IJJ
Re: Speed Issues
Thanks - hub is on the only socket in the house - same one Sky router was plugged into for years
Fixes: 392
Re: Speed Issues
@IJJ I suspect @Dan_the_Van  actually meant the test socket behind the master socket faceplate. Is your MS a single or dual-socket one?
IJJ
Re: Speed Issues
@jab1 single socket
Fixes: 392
Re: Speed Issues
OK. I  would still suggest you tried the test socket, via a filter.
IJJ
Re: Speed Issues
@jab1 so I think it's an NTE5 type. Are you saying remove front plate and plug the filter into the socket behind the faceplate?
Fixes: 392
Re: Speed Issues
@IJJ The NTE5 is the dual-socket type, can't remember the single socket designation. Yes, I am saying plug the filter into the test socket.
IJJ
Re: Speed Issues
@jab1 I think the dual is NTE5c but could be wrong - telecoms not my field. Further improvement when direct to the socket
Re: Speed Issues
Interesting stuff can be found from event log files, the first DSL Link Up message is, this will be 2023
08:24:34, 22 Dec. DSL Link Up: Down Rate=32400kbps, Up Rate=10271kbps; SNR Margin Down=9.2dB, Up=6.4dB
The was the last time your connection synced to 40000kbps, this will be 2024
18:58:11, 28 Jan. DSL Link Up: Down Rate=40000kbps, Up Rate=12461kbps; SNR Margin Down=8.9dB, Up=6.1dB
The speed dropped
10:14:46, 19 Feb. DSL Link Up: Down Rate=20388kbps, Up Rate=1127kbps; SNR Margin Down=6.2dB, Up=6.0dB
The fastest from that date was
06:23:44, 13 Apr. DSL Link Up: Down Rate=32599kbps, Up Rate=864kbps; SNR Margin Down=2.7dB, Up=6.0dB
Now it is
15:18:05, 12 Jul. DSL Link Up: Down Rate=55898kbps, Up Rate=12092kbps; SNR Margin Down=3.3dB, Up=6.3dB
For DSL Link DOWN there has been 17 since first switch on - the previous to today's DSL link down as a result of the test was
05:23:01, 02 Jun. DSL Link Down: duration was 550370 seconds
There have been a number of power off over the period which distorts the DSL connection time.
Re: Speed Issues
@IJJ
Are there any phone extension connected to the master socket, if unused suggest removing them
IJJ
Re: Speed Issues
@Dan_the_Van Not to the master that I can see. One line into the house that terminates at the master. There's a black box that runs from outside the house to the summer house but that is connected where the overhead cable meets the house. I think the previous owners had a second line for business.
Re: Speed Issues
There is another improvement using the test socket,  if it is hidden out of sight I would leave the DSL filter connected to the test socket.
@jab1
You are thinking of master socket 5c with a MK4 faceplate having the two ports.
IJJ
Re: Speed Issues
Yeah, there's a great big bookshelf in front of it....nearly gave myself a hernia shifting it 🤣
Thanks for all your help @jab1 @Marsh and @Dan_the_Van . I'll leave the filter in the master and keep an eye on it.
