Slow for Burrowbridge ?
stathe
I am always telling you  how slow Broadband is for me  and know it has been  faster so what should my speed be  in understandable   terms  what to realistically expect Thank you
2 REPLIES 2
cpc6128
Re: Slow for Burrowbridge ?
I believe you had a fault?
If so then your speed will be slow because of that fault but it should recover to what you had before given a bit more time. Normally takes around 10 days.
If it doesn't recover after this time I believe you can request a 'DLM reset' via the forums and this prompts it to restore speed. If the fault has been fully fixed your speed should then remain as fast as you saw it.
Fixes: 1,495
Moderators Note
Topic locked as there are multiple threads on this topic.
