Slow for Burrowbridge ?
- Slow for Burrowbridge ?
2 weeks ago
I am always telling you how slow Broadband is for me and know it has been faster so what should my speed be in understandable terms what to realistically expect Thank you
Re: Slow for Burrowbridge ?
2 weeks ago
I believe you had a fault?
If so then your speed will be slow because of that fault but it should recover to what you had before given a bit more time. Normally takes around 10 days.
If it doesn't recover after this time I believe you can request a 'DLM reset' via the forums and this prompts it to restore speed. If the fault has been fully fixed your speed should then remain as fast as you saw it.
2 weeks ago - last edited 2 weeks ago
Moderators Note
Topic locked as there are multiple threads on this topic.
