Slow broadband speeds again
Bren88
Hello,
My broadband speed has recently dropped to 22Mbps.
A similar thing happened this time last year and Openreach came out and were able to get it back up to 34Mbps.
Throughout the year though the speed had dropped again to 28 then 25 and now 22.
A few weeks ago the guaranteed speed was 28Mbps but that is now showing as only 22Mbps.
In the past I was able to get 40+.
Can anything be done to get my speeds back up to at least 30+?
Thanks.
This is a screenshot of the BT broadband checker...
...and the speed test result with the router connected to the test socket of the master socket.The download report button wasn't working for me.
15 REPLIES 15
Fixes: 357
Re: Slow broadband speeds again
@Bren88 Which Hub are you using?
The
sight of the broadband connection status from your Hub (with the 'Username' obscured) would help here.
For the Hub One -
For the Hub Two -
Mustrum
Fixes: 81
@Bren88   have you considered switching to FTTP (Full Fibre)?
You should be able to get better speeds than you are at the moment via your phone line, but perhaps for not much longer. In the mean time, is your line quiet - dial 17070 option 2?
Fixes: 466
Moderators Note
This topic has been moved from Full Fibre to Broadband
Bren88
@jab1  The router is a Hub One.
Fixes: 357
@Bren88 Thanks for that info.I suspect a BT/OR network issue, or possibly a phone fault - your DSL uptime is extremely low, and the D/S SNR higher than it should be. The WAN tab of your Hubs Event log would confirm my suspicions, but don't worry about it.
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Bren88
@jab1 Thanks for the reply.
Could the low DSL uptime be due to me disconnecting the router earlier today to test it at the master socket?
Doing the line test there is a very feint hum (I wonder if that could actually be the phone itself though. It is corded) and an occasional click that I can hardly hear roughly every 5 or 6 seconds.
Fixes: 357
@Bren88 That would account for the short uptime, but as I said, there is a BT/OR network problem - use the 'broadband' link I provided above - it may be a phone fault, but I doubt it from your description, and in any case if an engineer is required, they should check your phone connection anyway.
willcutforth
Fixes: 113
Hey there @Bren88 I hope you are ok.
Sorry about the delay in getting back to you. We've been super busy at the moment.
As @jab1 it looks to be a OR network issue but they need us to book an engineer. When would you be free for one? They do slots between 8am-1pm and 1pm-6pm.
Let me know.
 Will Cutforth
Bren88
Hey @willcutforth thanks for the reply
The 1pm to 6pm slot would be ok for me from tomorrow.
willcutforth
Fixes: 113
All booked in for you now @Bren88 I will keep an eye on this and get back to you tomorrow evening to make sure all is sorted Smiley Do you need anything else at the moment?
 Will Cutforth
Bren88
@willcutforth That's great. Thanks.
willcutforth
Fixes: 113
Just checking in @Bren88 everything all sorted now?
 Will Cutforth
Bren88
@willcutforth Yeah, all good. Speeds are now in the low 30's again.
Thanks for your help.
Brendan.
Fixes: 357
Glad to hear that - can I cross this off my 'watch list' now? 😀
