Download speed much slower than sync speed
PaulHP17
Hi all
After much grief with Openreach after a lightning strike I've finally got a stable connection again. However.....
Before the strike I was getting 60-62Mbps download, I'm now getting 45-52 on both wired and wifi connections . According to the BTW tester my line should be running at 68-69, and according to my Hub2 I'm synced at 62.
Weirdly, upload has stayed constant right through at about 15Mbps, and this is in line with the BTW result.
(Asus XT8 mesh in access point mode, Hub2 as router with wifi off. Same results +/- not much if I use a Vigor 166 as the router)
Any ideas ?
1 REPLY 1
Fixes: 383
Re: Download speed much slower than sync speed
@PaulHP17 Welcome to the forums. Staff response on here is very slow so:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
