Serious issue with connection
- Re: Serious issue with connection
04-02-2024 1:00 AM
Since Wednesday night out internet speed as dropped through the floor. We are on full unlimited fibre but since midweek connection has dropped to around 1 to 1.9. can't do a thing. Have raised a case and problem was found. Personally I think there are other issues, maybe an earth problem also.
The speeds have been dropping since we got the service.and cause buffering issues quite a lot but now it's really bad
Regards
Regards
Message 1 of 4
(1,242 Views)
3 REPLIES 3
04-02-2024 7:10 AM
@moggies2 If you have reported the issue, have you been offered an engineer visit? What Hub/router are you using?
Message 2 of 4
(1,207 Views)
04-02-2024 11:40 AM
@moggies2 I can see it has been raised and it's all external at the minute. We will keep an eye on it for you.
04-02-2024 12:51 PM
Thanks for update appreciated. Sky stream is useless at the moment 😬
Message 4 of 4
(1,137 Views)
