Cannot access a specific website using plusnet wifi??
Karen8
Trying to access a website that my WiFi will not allow me to? Works fine on mobile data so no issue with website.
5 REPLIES 5
Fixes: 392
Re: Cannot access a specific website using plusnet wifi??
@Karen8 Can you share the site, and what response do you get when you try?
the_groundsman
No intention of hijacking the OP and I'd be happy to start a new thread if they're unrelated.
I couldn't get onto https://incontrol.jaguar.com/jaguar-portal-owner-web/dashboard or communicate with my car via the mobile app. All other internet activity seemed fine. A router reboot solved it, but my first thought was it must be down for everyone given tother websites were fine
Why would a single site be impacted like this - and why was it local to me?
Fixes: 392
@the_groundsman Most probably totally unrelated, but what response, if any, did you get prior to the reboot?
the_groundsman
Website not found check connection.
Ran the troubleshooter.
Some DNS issue
Rebooted Router
All Good
Fixes: 392
OK - that can happen, very occasionally.
