SNR reset
- Re: SNR reset
- « Previous
- 1
- 2
- Next »
Re: SNR reset
25-01-2012 3:14 PM
Message 16 of 19
(233 Views)
Re: SNR reset
25-01-2012 3:18 PM
No it's still the same. Just took 10mins to update the AV on the laptop.
ADSL Link Downstream Upstream
Connection Speed 5248 kbps 832 kbps
Line Attenuation 33.0 db 17.0 db
Noise Margin 15.1 db 10.0 db
Message 17 of 19
(233 Views)
Re: SNR reset
25-01-2012 3:34 PM
Message 18 of 19
(233 Views)
Re: SNR reset
25-01-2012 4:59 PM
Thanks Adam. This is a wierd one. The engineer couldn't see why the throughput is so slow. He said my telephone line is clean as a whistle and the problem must be software based.
Edit: Thought I would add full router stats. Only rebooted a couple of hours ago though.
DS:
Noise Margin: 14.9 dB
Connection Rate: 5248 Kbps
Line Attenuation: 33.0 dB
Power: 19.8 dBm
Max Rate: 5280 Kbps
SuperFrames: 429283
SF (CRC) Errors: 6
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 3
Errored Seconds: 6
Severe ES: 0
Interleave Depth: 1
Bitswaps: 0
US:
Noise Margin: 10.0 dB
Connection Rate: 832 Kbps
Line Attenuation: 17.0 dB
Power: 12.5 dBm
Max Rate: 1076 Kbps
SuperFrames: 430641
SF (CRC) Errors: 16
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 6
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 1
Bitswaps: 0
DS:
Power: 19.8 dBm
Max Rate: 5280 Kbps
SuperFrames: 429283
SF (CRC) Errors: 6
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 3
Errored Seconds: 6
Severe ES: 0
Interleave Depth: 1
Bitswaps: 0
US:
Power: 12.5 dBm
Max Rate: 1076 Kbps
SuperFrames: 430641
SF (CRC) Errors: 16
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 6
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 1
Bitswaps: 0
Message 19 of 19
(233 Views)
- « Previous
- 1
- 2
- Next »
