Router Red Light
- Router Red Light
Router Red Light
28-04-2014 12:07 PM
Something unusual happened this morning which as never happened before the red light on my router which indicates my internet was on and off for a while,I also noted that the other lights were flashing I was not on my laptop at the time so I suppose I had lost my connection.I am curious why this happened because everything is fine now.
Message 1 of 4
(891 Views)
3 REPLIES 3
Re: Router Red Light
28-04-2014 1:06 PM
which light was red (usually internet or broadband) the former usually means authentication has failed and both lights would mean no connection to the exchange (no synch)
It's dropped a few times overnight from what I can see but not to a great extent:
Link to this file:
<img src="http://community.plus.net/visualradius/generated/image13986866835369.png"/>
Let me know if you have any further concerns.
Link to this file:
Message 2 of 4
(537 Views)
28-04-2014 5:28 PM
I had a problem when I switched on my laptop a little while ago it tells me I have limited access and was unable to connect so I disonnected and reconnected and we are back to normal, I have done nothing at this end to make things go wrong could there be a problem at the exchange or a router problem being a elderly gent I do not understand all this technical jargon.
Message 3 of 4
(537 Views)
29-04-2014 9:07 AM
No problem and glad to hear that's OK again.
If have any further problems just take a look at the router to see which light/lights is flashing if you can as that can help us understand the nature of the issue more quickly.
Message 4 of 4
(537 Views)
