Request for speed reinstatement after line fault
- Re: Request for speed reinstatement after line fau...
09-09-2014 9:11 AM
Coinciding with a recent phone line outage that lasted for 2-weeks (resolved on Friday 5th Sept, fault was external to the house) my PN fibre broadband speeds were drastically reduced. I was hoping they would have rectified themselves since last Friday but to date no improvement. Could someone at PN please give them a 'nudge' back up?
Originally - download 46-48MBs and upload 7-8MBs
Currently - download 25-27MBs and upload 4-5MBs
Gary
Re: Request for speed reinstatement after line fault
09-09-2014 9:12 AM
09-09-2014 10:32 AM
you have no choice but wait to see if DLM increases the profiles back up if at all, it never did for me i'm stuck on the speed i Dropped down to waited over 3 months for DLM to do Something, Plusnet conveniently put the lack of increase down to cross talk, I don't know if that's true or not, personally I believe a reset would get me back but that aint going to happen.
09-09-2014 10:34 AM
@ Terranova667 - Ask Plusnet to send you the results of a GEA test if you don't believe them.
09-09-2014 5:22 PM
Hopefully someone from PN will add their thoughts.
09-09-2014 5:31 PM
What's your IP Profile (Run http://speedtest.btwholesale.com/ and then Further Diagnostics)?
10-09-2014 10:35 AM
Download speed achieved during the test was - 27.46 Mbps
For your connection, the acceptable range of speeds is 60 Mbps-36.62 Mbps .
Additional Information:
IP Profile for your line is - 36.62 Mbps
Upload speed achieved during the test was - 4.97Mbps
I'm puzzled why it states that the maximum achievable download speed is 36.62 Mbs - as until the phone line fault I was getting 46-48Mbs on average, e.g. 44Mbs just two days before the fault occurred but mid-20Mbs ever since.
So do I need to refer a formal request to PN? Thanks for any advice.
Gary
11-09-2014 8:45 AM
11-09-2014 10:28 AM
I'm sorry to hear about the speed drops.
I'm slightly puzzled why you aren't getting the full profile speeds on your speed tests. The line is currently getting a throughput of 37MBps, are you running the tests on a wired connection?
The speeds have dropped but usually there's a reason for this, however it is worth raising a fault here so we our faults team are able to investigate further.
Dan
11-09-2014 11:14 AM
Thanks for picking this up.
It's a wired connection and tested with two devices - one an iMac the other a PC with same results. Tried it earlier this morning (0837 hours) and got 27.36Mbs down, 5.54Mbs up - which is fairly typical of late since the phone line fault.
However, just tested it again at 1102 hours after reading your response and got 34.98Mbs and 5.51Mbs respectively (again on both machines) so it looks like the download speed is getting there but the upload is lagging. Curious as to why it's suddenly increased in the last hour or two?
Having said that it's getting there i.e. towards the 36.62Mbs quoted max achievable speed - why is this so much lower than I had before the phone line fault (22.08.14) which was approx. 47Mbs? And will this return or do I need to raise a fault for that.
Gary
