Problems setting up a Netgear WiFi Range Extender with plusnet router
- Re: Problems setting up a Netgear WiFi Range Exten...
20-01-2013 6:19 PM
We have a plusnet wireless 563C8B router. To extend the range of this we have bought a Netgear Universal Wifi range extender WN30000RP. The connection appeared to go okay extending the existing network in that there is a good link rate, but it is not accepting the security password for the existing network (which it is supposed to do).
Any suggestions greatly appreciated. I have little technical knowledge unfortunately
Message 1 of 8
(8,065 Views)
7 REPLIES 7
Re: Problems setting up a Netgear WiFi Range Extender with plusnet router
20-01-2013 8:32 PM
You are honestly better off using powerline (or homeplugs known as) to put an access point (not a wireless extender).
Homeplugs are very simple, you plug one into the power socket by the router, you run a network cable from that to the router.
The homeplug uses the electric wires to form a network connection to the second one which....
The second homeplug is in the next location going into the wireless access point. This wireless access point have the same wireless settings as the router.
Bingo..... done. Any wireless devices will automatically connect to whatever is the strongest signal.
Message 2 of 8
(5,079 Views)
15-05-2013 10:01 PM
I've got the same problem. I hear what you're saying about powerline, but I already bought the netgear extender :(. What password is it looking for? I typed in the password I always use,the one on the
router, no joy. Do you think it's not accepting it because I have Plusnet fibre connection and not just plain broadband? Ideas please...me and my PC are strangers. I know very little about computers.
HELP!
HELP!
Message 3 of 8
(5,079 Views)
15-05-2013 11:17 PM
It's exactly the same password you use to connect any wireless device to your router. It's probably written on the router or on a label you were supposed to stick to the router. it's case sensitive so if it uses upper-case letters then you must to the same.
Message 4 of 8
(5,080 Views)
08-11-2014 12:55 PM
Were you able to solve this problem? I'm having exactly the same issue!
Message 5 of 8
(5,080 Views)
08-11-2014 3:13 PM
Hi all,
@ReedRichards Has hit the nail on the head about this issue.
If you're unable to connect to the wireless network using the password on the router (or on a sticker or card as often provided with such devices) then do bear in mind the password (or passkey as it's often called in relation to wireless networks) can be changed from it's default. You do this by logging into the router settings, this involves a separate login specific to the router.
Message 6 of 8
(5,081 Views)
08-01-2015 10:36 PM
Hello,
I am having the same issue. When I try to connect to the extender it asks me for the key, I enter the key and it doesn't recognise it. Has someone been able to solve the issue?
Message 7 of 8
(5,081 Views)
16-02-2015 10:03 PM
Hi folks,
Well - having had the same problem I think I've solved it. It appears that the NetGear extender doesn't like the default password that the plus net router uses (I hadn't bothered to change mine since getting plus net last year). So, don't use the automatic WPS setup as this will try to keep the same password. Instead use the Netgear setup genie (if you've already used WPS you'll need to reset the extender using the old paper clip in the tiny hole trick!).
Simply follow the setup steps and then when it gets to the point where it says "Use the same password" (or words to that effect), unstick the box and create a separate password.
And it appears to have worked! Whooppeee!
Good luck - let me know if it works for others.
S
S
