Problems Again
- Re: Problems Again
Problems Again
26-05-2014 11:34 AM
Problems have started again from what i can see in logs it started wednesday, the last time i checked stats they where :-
2.1 Type VDSL
2.2 Status Up
2.3 Uptime 27 days 16 hours 24 mins 13 secs
2.4 Line Rate (Down / Up) 74253 kbps / 20000 kbps
2.5 Noise Margin (Down / Up) 5.9 dB / 14.9 dB
2.6 Attenuation (Down / Up) 11.5 dB / 4.6 dB
2.7 Power (Down / Up) 12.8 dBm / 6.9 dBm
the uptime was longer and as you can see good stats, then noticed i had a disconnect wednesday which ended with a sync speed of 68000kps but left it it will put itself right so i thought , but i have been having a few since then and stats have gone down as you can see even further :-
2.1 Type VDSL
2.2 Status Up
2.3 Uptime 0 days 0 hours 9 mins 17 secs
2.4 Line Rate (Down / Up) 59888 kbps / 19628 kbps
2.5 Noise Margin (Down / Up) 6.2 dB / 5.9 dB
2.6 Attenuation (Down / Up) 11.6 dB / 4.6 dB
2.7 Power (Down / Up) 12.8 dBm / 6.8 dBm
Now the only thing that has changed my end that i am aware of is on monday last week i started playing BF4 (battlefield 4 ) surely playing a game can`t cause this ?.
2.1 Type VDSL
2.2 Status Up
2.1 Type VDSL
2.2 Status Up
Message 1 of 6
(1,193 Views)
5 REPLIES 5
Re: Problems Again
26-05-2014 9:25 PM
Has your sync speeds increased again now?
did you notice the drop in sync speeds?
Message 2 of 6
(740 Views)
Re: Problems Again
27-05-2014 7:05 AM
Hi Chris,
It disconnected again yesterday around dinner time yesterday, did improve but not by much.
2.1 Type VDSL
2.2 Status Up
2.3 Uptime 0 days 18 hours 48 mins 5 secs
2.4 Line Rate (Down / Up) 60048 kbps / 19534 kbps
2.5 Noise Margin (Down / Up) 6.4 dB / 6.2 dB
2.6 Attenuation (Down / Up) 11.6 dB / 4.7 dB
Andy.......
2.1 Type VDSL
2.2 Status Up
Andy.......
Message 3 of 6
(740 Views)
Re: Problems Again
27-05-2014 10:13 AM
Thanks for getting back to me.
Your line has disconnected around 4/5 times over the past 2 days, something has caused interference and the line has generated errors as a result which has meant that DLM has taken the necessary action.
try and keep your equipment connected and keep the line stable and things should pick back up.
Message 4 of 6
(740 Views)
Re: Problems Again
02-06-2014 11:19 AM
I had an engineer out on saturday , tested everything and all came back fine so looks like was a temporary glitch which is good :). However he was having problems himself and was having trouble resetting the line and he told me to wait 4 hours to see if it goes through which it hasn`t, he then told me i had to ring back up to get someone else out . So now this has made my line now worse because while he was out i think it was 2/3 times he just turned the router off while testing, so the follow morning round 5/6am router goes off again sync speed further down . I phoned up on sunday morning and now am told it can take 3/4 days for a reset to go through should`nt it be sorted when an engineer comes out fairly quickly or at least within the 4 hours like he said? ( #86181784 ).
Andy......
Andy......
Message 5 of 6
(740 Views)
Re: Problems Again
02-06-2014 11:24 AM
I've just taken a look at your line and it looks error free, however, Interleaving is on high.
The line is going to need a bit of time to ensure it remains stable before the sync rate goes up. I'm not sure why the engineer couldn't complete a DLM Reset. Give the line a little bit of time to stabilise and I'm sure the speeds will return back to normal.
Message 6 of 6
(740 Views)
