Plodding Upload
- Re: Plodding Upload
- « Previous
- 1
- 2
- Next »
Re: Plodding Upload
27-11-2014 12:38 AM
Current line speed:
13.6 Mb
13.6 Mb
Message 16 of 19
(470 Views)
Re: Plodding Upload
27-11-2014 9:14 AM
That is what it should be. The speeds you get should approach that.
The TBB tester is probably the best. If the x6 download is a lot faster than the single that is often a sign of BT exchange contention.
Message 17 of 19
(470 Views)
Re: Plodding Upload
27-11-2014 1:40 PM
Quote from: Wingco39 Should I just do a reset every so often to get the speed back up again?
No! If the line remains stable, you should see no changes from where you are. Your current synch is exceeding expectations for your line's reported attenuation.
If for some reason your line resynchs at night time and later on during day time you see the SNRM figures markedly higher than 6dB you might see some synch speed improvements by doing a reset.
Aside from the above unnecessary resets could be quite detrimental to the operation of the line, as DLM will kick in to manage what it perceives to be a stability issue.
Message 18 of 19
(470 Views)
Re: Plodding Upload
27-11-2014 5:26 PM
Thanks guys for all your help on this one Until the next time.
Message 19 of 19
(470 Views)
- « Previous
- 1
- 2
- Next »
