Pants Broadband.... Fault Ref: 69636053 & 69636077
- Re: Pants Broadband.... Fault Ref: 69636053 & 6963...
Re: Pants Broadband.... Fault Ref: 69636053 & 69636077
14-08-2013 11:40 AM
The line is definitely stable enough for a reset, my only concern is whether it'd retrain at a similar speed. I guess it's either that or escalate as a speed fault, please let us know which way you'd rather proceed?
14-08-2013 6:59 PM
Can you try an SNR reset and go from there.
15-08-2013 9:21 AM
15-08-2013 9:36 AM
15-08-2013 2:54 PM
Quote Thanks for your patience.
I have checked your line and the diagnostics are showing a potential issue in the local network. I have now raised this with our suppliers so they can get this resolved. We will continue to monitor the fault for you and keep you updated, we aim to do this as soon as we can but it can take up to 72 hours.
I would like to apologise for any inconvenience this may be causing you.
Ahhh.. so I'm not going mad after all!
Thanks for whoever has taken a proper look at the line etc
16-08-2013 8:53 PM
Quote ***Internal***
DSL:
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status: NTE Power Status: PowerOn Bypass Status:
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 40.8 66.5
SNR Margin: 6.5 5.8
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 913561 1185822
Speed: 664 2208
Maximum Stable Rate (KBPS): 864 Fault Threshold Rate (KBPS): 691
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 2215
Indicative Line Quality: A Mean Time Between Errors Downstream (Seconds): 2215
DLM Data: WP profile - 2200
BRAS Profile: adsl1014, Profile Info: WBC 160K - 24M Medium delay (INP 1) 6dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+)
PTTR: No Result
CLT: FAULT - Dis One Leg in Exchange
Fault was raised... However a rather befuddled BT Engineer called this morning at 7.30 on my mobile, and says hes been given a different landline number, has rung them and confused the woman..
I confirm my landline, he says he actually has that too... but the routing information he has is all for the wrong number. .
Ring PN and tell them.. to be told as the engineer hasn't closed his job that there's nothing they can do until he does.. lo and behold, I get home and find no update. .
I assume looking at the above that I should have a 2200profile, but aren't getting it or syncing at it..
Wierdly, the fault as diagnosed by PN says one leg is disconnected.. the landline works however. And I've seen one leg disconns stop the landline from working.
BTW I can confirm the ONLY connection is currently to the Test Socket and thats how its staying till this issue is bottomed!
17-08-2013 8:49 AM
Quote Link Information
Uptime: 1 day, 0:29:42
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 664 / 2.421
Data Transferred (Sent/Received) [GB/MB]: 1,41 / 418,86
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 40,8 / 65,0
SN Margin (Up/Down) [dB]: 5,8 / 4,1
Loss of Framing (Local/Remote): 76 / 0
Loss of Signal (Local/Remote): 9 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 9.719 / 0
FEC Errors (Up/Down): 14.147 / 11.437.170
CRC Errors (Up/Down): 86 / 4.102
HEC Errors (Up/Down): 86 / 4.80
17-08-2013 8:57 AM
Despite the PN fault diagnosis.. and that it was also stuck on BRAS with 1014...
My whitebox shows a marked improvement, clearly just from the SNR reset. Hopefully someone will fix the line and it'll be even better.
This is "fair warning" to PN however, knowing how bad Openreach are.. I won't be paying for the fault should the diagnosis turn out to be pants... I really can't see how I can have a one leg dis fault, yet my landline work fine..
17-08-2013 9:29 AM
So unless the reported fault is screwing up your attenuation you won't get much better
As a check if you put your post code in here http://www.kitz.co.uk/adsl/adslchecker.php - not your phone number
What does it give as distance from the exchange
17-08-2013 11:59 AM
I initially complained as my line was much worse than previously... and even worse after having a new NTE and drop line.
PN checked the line, and did an SNR reset, and they also found a fault with the line when completing a Copper Line Test which came back as a wiring issue, one leg disconnected..
Hence why they booked an engineer... then the engineer had the wrong information.. so couldn't do any work.
Next after a call to PN for updates, get told it looks like its fixed... (righto.. it just fixed itself...) and quite frankly got a fob off from the guy on the phone who seemed quite incapable of anything other than repeating what he said before but in a different way.
Anyway as I passed an OR engineer earlier, I stopped and enquired. He said a one leg dis fault would "normally" kill the line, however he said if the lines working, its more than likely to actually be a HR (high resistance) fault masquerading as a one leg dis fault...
He agreed that its highly unlikely to have "fixed itself" as they never do, and also said its likely to kill my bb speed again in short measure.
As it is its magically managed nearly a 150% sync improvement.. not bad considering I was told 1mb was the best I could get.. Despite having had much better before.
I'm not asking for 8mb.. but when a property some 5 doors away, fed from the same post can expect 2mb.. why can't I?
PN had best find out what happened with the engineer and report back as to what they intend doing, as it's going to get fixed this time for good, especially as they've just put up prices..
dick:quote
19-08-2013 8:44 AM
19-08-2013 3:38 PM
Quote We are pleased to be able to inform you that a member of our Customer Support
Centre has now escalated your Question [number 73064677 ]
for further investigation.
The following comment was added to the Question
Dear Mr xxxxx,
Thank you for your patience.
I am sorry to hear you have been experiencing issues with your internet connection.
Since the engineer attended and replaced the dropwire, your issue now appears solved as your connection is stable at a speed of 1.5Mbs. Please continue to monitor this and let us know if you experience any further issues.
I do apologise for any inconvenience this problem may have caused.
Im sorry. . Do you have issues understanding what I had said?
19-08-2013 4:06 PM
19-08-2013 4:19 PM
19-08-2013 7:56 PM
This morning we have @2000 and I get home to 1700.
As the engineer said.. it'll soon drop and sure as .. it is!
Should I also mention before the last fault, it was going very well.. and without interleaving!
Now I have a new line, NTE and connection straight to test socket plus interleaving and its running like a sack of spanners!
I look hearing from someone who is technical
