House re-wre
gwillym
House re-wre
Starting on Monday (2nd Sept) the electricians are going to completewly rewire my house. This obviously means that during the next 10 - 14 days the power (& hence my modem & router) are likely to be off an on intermittently. Can anyone give me an idea of what this will do the my IPProfile ( I'm assuming it will get trashed?), and what, if anything I can do to get it back afterwards to the 53/13 I'm currently getting.
thanks
Neil
198kHz
Aspiring Champion
Fixes: 13
Re: House re-wre
Are you near enough to (and on good terms with) a neighbour who would let you run the modem and router off an extension lead?
Remember you are unique - just like everyone else
IndiaBravo
Re: House re-wre
Couldn't you just turn it off for the duration? If the powers going to be on and off constantly you're presumably not going to be using it?
gwillym
Re: House re-wre
The kit will be on/off intermittently - I was just wondering what the DLM would make of it?
Re: House re-wre
Avoid too much on/off if possible, if switching off disconnect first via the router interface (if you know it's about to be switched off).
Call me 'w23'
Re: House re-wre
As W23 says, if you make sure to disconnect via the router's interface prior to turning it off you should be fine as that way it won't be picked up by the DLM system as a possible fault.
