Not really a new topic - Peak Time slowdown still happening.
- Re: Not really a new topic - Peak Time slowdown st...
21-04-2013 7:27 PM
run this afternoon.
As advised in the long-running thread in the Announcements forum a few weeks back, I've raised a fault (#68600921) - this is just so the DCT can see that the issue is still occurring, and it isn't an issue with my line or equipment, otherwise it would happen all the time, and not just at peak times.
Other people I have spoken to on my exchange (NSIMD) have reported similar issues, so it seems likely that its either a capacity issue, or it's something to do with the preparatory work for fibre, which is due to go live by the end of June. [1]
[1] Not holding my breath - lots of fibre cabinets about the place, but not adjacent to my PCP
Re: Not really a new topic - Peak Time slowdown still happening.
22-04-2013 12:32 AM
22-04-2013 2:58 AM
(Normal speed is 19mb/s ish)
Perhaps it's my Magic Mouse !!
22-04-2013 7:31 AM
22-04-2013 9:42 AM
Jaggies: Yours sounds like BT side contention to me.
Ex-Broadband Service Manager
22-04-2013 9:48 AM
22-04-2013 10:09 AM
22-04-2013 10:19 AM
22-04-2013 10:19 AM
Edit: you will also see that my connection still drops once or twice a day for no apparent reason.
22-04-2013 4:31 PM
Quote from: Kelly Jaggies/Shalom: What gateways were you on?
Currently on pcl-ag01, but my connection has been a bit up and down over the weekend as well, so I'm not sure what gateway I was on when I ran the tests. I'll check again this evening and update the thread.
Quote from: Kelly Jaggies: Yours sounds like BT side contention to me.
I've already noted my suspicions on that score in the Fault ticket.
22-04-2013 8:23 PM
22-04-2013 9:36 PM
I was actually wondering was it throttling or general ISP congestion, quite hacked off by it i must say. Now that ive seen this post i do wonder if its exchange based as im also on the NSIMD exchange (though presumably just a bit further out of town judging by the 13mb/s speeds obtained by the op). Its really quite a drag and im considering raising a fault but im kinda loathe to have to go through the whole test socket yadda yadda shennanigans.
23-04-2013 12:20 AM
23-04-2013 10:03 AM
I can see you've raised a fault and we'll be replying to you ASAP, in the meantime would it be possible for you to perform a speed test at http://speedtest.btwholesale.com
@MrK
You're on the same exchange as Jaggies, would it be possible for you to perform a speed test at the above link and then run through our faults wizard at http://faults.plus.net and we'll get this picked up?
23-04-2013 10:15 AM
Non BT test but just as a fyi, this is standard speed for me and in accordance with my sync speed and long line.
