No connection,help.
cslogg
No connection,help.
My connection went down at 7.30 last night and still not back.
Did everythingI can think of.Reset modem etc.
3 REPLIES 3
Fixes: 383
Re: No connection,help.
@cslogg What colour/state is/are the light(s) on the router? Which router are you using?
I suggest you report a fault via https://www.plus.net/help/report-a-problem/
Are you on FTTC or FTTP (full fibre)?
pvmb
Aspiring Champion
Fixes: 15
And do you have a landline?
Fixes: 246
Have you called support...
