No Internet & NO Internet light on router Thursday 19th April 4pm
- Re: No Internet & NO Internet light on router Thur...
Re: No Internet & NO Internet light on router Thursday 19th April 4pm
24-04-2012 5:49 PM
1. Best Effort Test: -provides background information.
Download Speed
11.2 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 11.2 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.13 Mbps
Upload Speed
0.38 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.38Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
![](/skins/images/C04E6B84094581258F5B11805D841E46/responsive_peak/images/icon_anonymous_message.png)
24-04-2012 5:56 PM
24-04-2012 6:10 PM
24-04-2012 6:12 PM
24-04-2012 6:18 PM
24-04-2012 6:24 PM
24-04-2012 6:37 PM
24-04-2012 6:55 PM
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: ADSL2+
DSL Channel:
DSL Upstream Rate: 444 Kbps
DSL Downstream Rate: 16015 Kbps
Down up
DSL Noise Margin: 7.9 dB 27.4 dB
DSL Attenuation: 24.0 dB 10.4 dB
DSL Transmit Power: 0.0 dBm 12.9 dBm
24-04-2012 6:57 PM
The line rate or IP profile looks fine as per a line check I've just done for you. This looks like what we'd usually class a performance issue so I'd advise raising a fault here: https://portal.plus.net/apps/kbdfaults
Do reply back when you have.
Adam
24-04-2012 7:12 PM
I've raised a fault.
Regards,
Mark
24-04-2012 7:17 PM
24-04-2012 7:22 PM
Should I close the fault?
24-04-2012 7:26 PM
If your download speeds do seem poor at the moment see what the BT speed tester displays: http://www.speedtester.bt.com/
24-04-2012 11:31 PM
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
24-04-2012 11:39 PM
