No Internet & NO Internet light on router Thursday 19th April 4pm
- No Internet & NO Internet light on router Thursday...
- « Previous
- Next »
Re: No Internet & NO Internet light on router Thursday 19th April 4pm
24-04-2012 11:44 PM
Provided the alternative (without the www) in case i'm not the only one.
24-04-2012 11:51 PM
That's in both FF 11.0 & IE8 for all of them.
25-04-2012 1:11 PM
You do not have the
Java Runtime Environment
installed for applet support.
We have detected that Java is not installed or enabled on your device.To use the diagnostic tests on this Performance Tester Java must be installed on your device and enabled in the browser.To install latest version of Sun JRE, available for Windows, Linux, OS X, Solaris and other operating systems please click here.
Please Note : After installing Java, please close and re-open your browser to access the diagnostic tests(http://speedtester.bt.com/)
If you still face the same problem please go to theFAQ section to help troubleshoot.
If you are unable to install Java or do not wish to, you can still see how fast how fast your broadband is going with our Beta speedtester.Please click one of the buttons below.(Please note you will need Flash enabled on your device in-order to use the Beta speedtester)
And if you click on the beta
you get a similar result to http://www.speedtest.net/, eventually.
(Without diagnostics)
And it's not as pretty !
25-04-2012 2:19 PM
26-04-2012 10:23 AM
26-04-2012 12:07 PM
When I have used http://www.speedtester.bt.com ; the results are similar, if slower and more convoluted for me to access it, as per Java posts above and change of browser.
02-05-2012 2:58 PM
Hi Joanne,
Could you check my account again for the error in my usage please? I seemed to have a really slow speed last night, nearly unable to view youtube videos.
02-05-2012 4:48 PM
I've had it manually reset now so you should see the difference.
Jojo
04-06-2012 7:16 PM
Hi Joanne,
Seems as if its happening again unfortunately Seems to work perfectly for a few days and go back to either around 30kb/s or 200kb/s. Today seems drasticaly slow. I've sent you a PM.
Could you have a further look into it please?
06-06-2012 1:54 PM
is this happening all the time or just certain times of the day?
Jojo
06-06-2012 6:09 PM
07-06-2012 9:34 AM
- « Previous
- Next »
