Slow speeds fro 2 weeks
- Slow speeds fro 2 weeks
03-06-2012 2:00 PM
For 2 weeks now my broadband has slowed from its usual 1.8 Mb/s download to around 700 Kb/s. Upload speeds have also suffered.
Router stats:
Uptime: 1 day, 21:58:55
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 804 / 1,664
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,632
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 349.91
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 15.0 / 11.5
Vendor ID (Local/Remote): TMMB / P
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 196,636 / 0
FEC Errors (Up/Down): 180 / 76,794
CRC Errors (Up/Down): 146 / 1,778
HEC Errors (Up/Down): 171 / 11,557
BT Speedtest Result:
Download (Mb/s): 0.73
Upload (Mb/s): 0.13
Ping Latency (ms): 40.38
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
0.75 Mb <-----------This used to be 2Mb/s - 3Mb/s ???????
Router stats:
Upload (Mb/s): 0.13
Current line speed:
Message 1 of 5
(1,037 Views)
4 REPLIES 4
Re: Slow speeds fro 2 weeks
03-06-2012 8:19 PM
You need to run the BT Speedtester Diagnostic test to see what it says for the IP Profile for your LIne. Post the full results from that Test and the modem/router ADSL stats taken just before or just after the test. It sounds like you've had a low sync event at some point. Are you on 20CN or 21CN?
Message 2 of 5
(472 Views)
06-06-2012 1:40 PM
HI esberger2012,
Can you tell me if you're using any extension cables/sockets? Do you have a test socket you can plug into?
Jojo
Jojo
Message 3 of 5
(472 Views)
06-06-2012 7:09 PM
I can't complete the bt diagostic test, it tells me there was an error.
The router is currently plugged into the test socket, no extensions being used. Speeds are still very slow and there is intermittent pauses where any downstream data seems to stop for a few seconds.
Message 4 of 5
(466 Views)
07-06-2012 9:44 AM
Hi esberger2012,
I've just checked you line and your sync rate is now 2144 since you reconnected. Once the line has been connected for up to 72 hours your IP profile will increase to 1750. At the moment your IP profile is 1250 on both BT and Plusnet's systems.
Jojo
Jojo
Message 5 of 5
(466 Views)
