No DSL Connection
- Re: No DSL Connection
No DSL Connection
15-06-2012 8:13 AM
Hi
Since yesterday morning i've had no internet. I've checked my phone line which is fine, i've also tried logging into my router, its been disconnected and will not recennect, saying 'DSL connection is down' the router show most of the lights flashing all except the most important one called 'internet'. Can somebody help me out please.
Regards
Regards
Message 1 of 8
(7,154 Views)
7 REPLIES 7
15-06-2012 9:11 AM
I've just performed a line test for you and the results show me that the line is out of sync, that means your router is not picking up the broadband signal from the exchange.
We'd always recommend raising this with support as a first port of call. That can be done by raising a fault here: http://faults.plus.net or give our support team a call on 0800 432 0200.
Let us know via here if you have any difficulties beyond that.
Adam
Adam
Message 2 of 8
(4,571 Views)
15-06-2012 9:35 AM
Thanks for the quick reply Adam, i'll give them a bell. Cheers
Message 3 of 8
(4,571 Views)
15-06-2012 11:11 AM
Message 4 of 8
(4,571 Views)
18-06-2012 11:31 AM
Hello Guys
I had this issue looked into and and it seemed to be a a sync problem, it was resolved late friday night however an hour later the same problem reoccured and i've been without the internet all weekend now.
I have the intital ticket #56562748 still open i believe could this been looked into please.
Message 5 of 8
(4,571 Views)
18-06-2012 4:24 PM
I can see one of our faults agents has now tested and raised this to our suppliers, so it's under investigation. We'll let you know as soon as we get an update.
Message 6 of 8
(4,571 Views)
18-06-2012 5:13 PM
Quote from: TechnicA1 ,,,,,,,,,,,,,,,,,,,,,,,, the router show most of the lights flashing all except the most important one called 'internet'.
If the Internet light is was out, that indicates you don't have a PPP session, which would be true if your sync was down. A Broadband light (if that is what it's called on your modem/router) flashing indicates that you don't have sync with the exchange and the modem/router is trying to do so.
Message 7 of 8
(4,571 Views)
19-06-2012 10:20 AM
Message 8 of 8
(4,571 Views)
