New customer - lower speeds than expected?
- Re: New customer - lower speeds than expected?
- « Previous
- 1
- 2
- Next »
02-08-2015 11:18 PM
Re the drop in attenuation, around 3dB is common between ADSL2 and 2+. (As I think you posted in your OP).
ADSL2 attenuation is the same as ADSL as they use the same frequencies. ADSL2 is just a better protocol. When you go to ADSL2+ the greater attenuation on the higher frequencies is included in the average figure we are given in the simple stats. Hence the rise in average attenuation. (Some router/MSAN combinations do seem to keep the attenuation the same somehow).
You greater drop will be a combination of the 2.5-3dB you saw before and probably a different way of calculating the average between the two routers. When I was on ADSL2+ my Linksys router reported 52.5dB. When the wireless on that died I replaced it with a Speedtouch 586 and straight out of the box that gave 49dB and a sync increase of about 700kbps. Which goes to show not everything about stats is black and white. Later Netgear 834s gave the same as the Speedtouch.
04-08-2015 10:18 AM
I've been on adsl2 for a few days now and it's rock solid stable. I simply disables adsl2+ in my router. I'm hoping the higher sync speeds (nakedly upload) will be picked up by the system and I'll be able to increase the down sync speed. I have noticed the down sync SNR is sitting at about 6.5dB so there is still capacity in the line.
I need to get it set to a 3dB profile tho, perhaps I'll message one of the staff who replied above.
04-08-2015 11:06 AM
04-08-2015 12:52 PM
I'm currently connected to a bt open reach filtered face plate that was fitted earlier this year so no filters are needed elsewhere.
The drops you see will be from me reconfiguring my router at the weekend. Prior to this I had 10 days stable and it's been stable since
Can you put me on 3dB profile please?
04-08-2015 5:01 PM
04-08-2015 5:48 PM
I'll leave the line some for a few days to allow my bras profile to catch up as it's still at 7mb. I guess this just takes a little time.
Thanks again.
Upload stuck at 768kbps
10-08-2015 10:37 PM
For some reason tho no matter when I resync my upload always syncs at 768kbps. This is using the 2704n router supplied by plusnet and connected using ADSL2+. If I use my own sagem router and force it to ADSL2 only the upload syncs at close to 1100kbps but the drop on download is significant.
I've read about capped uploads on here but they seem to be at 448kbps. Is there any reason my line is being capped at 786kbps and if so is it possible to remove said cap or otherwise boost my upload? Surely adsl2+ should be able to sync higher than adsl2!
Does a 3db upload profile exist? Would my line benefit from annex M?
Thank you
Re: Upload stuck at 768kbps
11-08-2015 6:53 AM
11-08-2015 11:20 AM
Topics merged to keep everything in one place.
13-08-2015 1:34 PM
There isn't a 3db upload profile. According to this document, the upload target is either 6 or 9.
Annex M, I doubt it would be worth it, you would lose some download bandwidth.
Perhaps something else to check and consider is if interleaving on. Interleaving off for the upstream might improve the speed slightly. Usually switching interleaving on or off is handled automatically by the DLM, and the DLM seems to be pretty keen to switch interleaving off for my line at least.
17-08-2015 9:26 PM
- « Previous
- 1
- 2
- Next »
