New FTTC install, slow speeds
- Re: New FTTC install, slow speeds
06-04-2014 9:17 PM
Can someone please take a look?
Ticket open since Friday due to BTO sending 2 seperate engineers to do the line and FTTC install! (ticket 83816427)
Results from BT checker.
BT BROADBAND AVAILABILITY CHECKER
Telephone Number xxxxxxxxxxx on Exchange MONTFORT is served by Cabinet 43
High Low High Low
FTTC Range A (Clean) 80 66.8 20 19.9 -- Available
FTTC Range B (Impacted) 79.5 52.1 20 17.7 -- Available
Bt speedtest result
Results Image not loaded
1. Best Effort Test:
Download Speed : 33.22 Mbps
2. Upstream Test:
Upload Speed : 13.34 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
07-04-2014 12:24 AM
What was the IP Profile on your BTwholesale speedtest, and what is your Plusnet Current Line Speed?
(You may have to wait a while to get the answer - as I type the site is down for maintenance).
07-04-2014 7:20 AM
Phone exchange:
MONTFORT
Estimated line speed:
66Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-03-20 14:15:31
Current line speed:
37 Mb
BT test fails with a error (see original post)
07-04-2014 11:42 AM
I'm really sorry for the problems that you're experiencing with low speeds. I've made some back end changes with your Speed Profiles. Can you please restart your router and let us know if the speeds have increased for you?
07-04-2014 1:56 PM
I still cant see my profile on the BT checker website though?
08-04-2014 4:12 PM
05-05-2014 11:30 AM
Quote from: Chris That should display once the back end systems have had time to populate.
I still cant see this?
Getting loads of disconnects and generally laggy browsing.
Can you check your end? It seems that the router is rebooting? (I managed to check the setup when it did it just now and I saw that the LAN1 light was out on the modem, but power/DSL were lit)
Do I need to raise a fault?
06-05-2014 1:42 PM
<img src="http://community.plus.net/visualradius/generated/image13993800708354.png"/>
From the drops seen above, are any of these from the modem/router being restarted?
Are you connected via Ethernet or Wireless? If Wireless, could you try an Ethernet Cable please?
06-05-2014 2:14 PM
I'm connected wired to the router.
I have not rebooted the router at all. The resets are the router rebooting itself.
I can see the resets emptying the logs.
I also see the latency change in my tbb ping graphs is this normal?
06-05-2014 3:22 PM
06-05-2014 3:55 PM
http://www.thinkbroadband.com/ping/share/d93d8ee745f9b049bbfc40a8be97404a.html
06-05-2014 4:57 PM
08-05-2014 7:26 PM
I have had more reboots, latest just now (approx 19.20).
Do you think the router is at fault?
08-05-2014 10:38 PM
09-05-2014 7:01 AM
Seems to be when in use with several devices.
