Anyone experienced DNS problems 23rd May 12pm -2pm GMT?
lorisarvendu
Resolving web pages timing out, lookups not working, LastPass saying "Can't get to login server".  Router's config page slow to come up, even after a reboot.
All this through a very stable VNC session through an SSH connection from work...and then suddenly it's all working again.
Was it just me?
A tortoise? What's that?
You know what a turtle is? Same thing.
Fixes: 165
Re: Anyone experienced DNS problems 23rd May 12pm -2pm GMT?
Yep, we're aware and looking:
http://usertools.plus.net/status/archive/1400850987.htm
 Chris Parr
 Plusnet Staff
Finguz
Yes I had this for a minute or two about 45 minutes or so ago, connected to ptn-bng01, but it seems to have cleared up now.
zxcvbnm
Yup, all stopped here so switched to 8.8.8.8 for the moment and it works again.
Fixes: 26
I encountered this too.  Ran a number of nslookup queries which all timed out.  Switched to Google's DNS address and all OK.
I've noticed this problem profile a number of times when posting to the forums; all is fine and then for a couple of attempted saves, one gets page cannot be found check URL.
Something is badly broken or configured, because it appears that when this happens access to both DNS servers is lost.  I have previously expressed concern about both DNS servers being in the same subnet.
lorisarvendu
Well the first thing I always try is rebooting the router, but even the router's pages were massively slow to respond.  Why would that be, since I'm not using DNS to reach my router?
I can see why the SSH and VNC connections would be stable, since I established them from the other end so they were using my DNS servers here at work.
Fixes: 4
I had streams freezing on iplayer around this period also
Fixes: 165
How's it looking now? Should be resolved so we'll monitor before closing the service status.
 Chris Parr
 Plusnet Staff
buseng12
I had the the same, couldn't access any web sites/pages although all the router lights including internet were green.
Re-booting the router seemed to clear it.
lorisarvendu
It was resolved for me 5 minutes before I made my post, and it's been fine ever since.
Fixes: 4
Ok at the moment
Finguz
Everything is still fine here.
Fixes: 165
Thanks all, closing off the service status shortly.
 Chris Parr
 Plusnet Staff
Fixes: 26
Chris,
It coughed again at 18:30.
I see these symptoms nearly daily, particularly when in the forums.  I can setup some diagnostic feedback for you if it helps.  Just tell me what you need.
Kevin.
