My computer's internet connection speed isnt as fast as any other device
- Re: My computer's internet connection speed isnt a...
10-12-2017 12:14 PM
I use my computer for gaming such as: Destiny 2, Rainbow Six Siege but I am not able to play them due to my connection speed. My brothers PS4 can run Rainbow six siege and destiny 2 fine without lag.
here are my speedtest.net results in Mbits
Ping: 38ms
Upload: 0.35
this is the sort of internet speeds i get with no one in the house but i still cant play those games smoothly. Please help
Re: My computer's internet connection speed isnt as fast as any other device
12-12-2017 1:31 PM
to diagnose the propblem we need to know a little more . Lets start here
Are you using wired or wifi connections?
if you are both using wifi, what's the distance between your equipment and the router? Wi-fi is only a weak signal in most cases, dependent on make and model. Is there anything in the way? Wifi is distance dependent and is also affected by walls, ceilings, other electrical apparatus and even furniture! I have even known an ironing board to affect a wifi signal
If you are both using the internet at the same time, and one is wired and one is not, there could well be differences in percived connection speed.
12-12-2017 2:39 PM
Hello there and welcome to the community forums.
I agree with gpsmout. it'd be useful to know whether your PC is hard wired to your router or using the WiFi.
-Anoush
