My Opinion
- Re: My Opinion
Re: My Opinion
06-05-2009 5:45 PM
if you click connect it may get you back on the internet with out having resync untill we can find a permanent soultion to this problem for you
Re: My Opinion
06-05-2009 7:06 PM
I will do it next time it happens and let you know if it works. All i know is that whhen the internet light goes off, and try to access
or open my browser to use the internet, a blanck page appears telling me that I cant access intenet.
Re: My Opinion
06-05-2009 7:12 PM
If it were about:blank in IE or just blank in FF then you wouldn't get the popup.
Connecting to the browser doesn't require internet access.
I can't remember which router you are using but the probable links to access the browser are
http://192.168.1.254 (Speedtouch router)
http://192.168.0.1 (Netgear and most other routers)
Re: My Opinion
06-05-2009 7:45 PM
Edit: If perchance your wireless connection locks up, try connecting the laptop with an ethernet cable remembering to tell the laptop to connect by ethernet instead of wireless.
Re: My Opinion
06-05-2009 7:58 PM
Re: My Opinion
06-05-2009 8:59 PM
Re: My Opinion
06-05-2009 9:00 PM
Re: My Opinion
06-05-2009 9:25 PM
Re: My Opinion
06-05-2009 9:27 PM
There are a couple of things you could try here, check your wireless is set up securely, WPA encryption, a passphrase that is not a simple word and try a different wireless channel, this sounds as though something is interferring with the wireless causing the router to lock up.
Before the next bit , what are the current line stats?
If, having checked out your wireless and changed channel, the problem still arises, time to change routers and see how it goes.
Edit:spelling!
Re: My Opinion
06-05-2009 9:32 PM
If this is the case it appears to me that it is a router problem as you are still accessing the router but it won't login to Plusnet without a router reboot
Re: My Opinion
06-05-2009 9:58 PM
Quote from: Oldjim If I am reading your screen shots correctly you accessed the router and clicked on Connect and it just hung there not connecting.
That is exactly what did happen....At last you all starting to realice why I keep rebooting the router..... For a minute I thought I was going MAD.
Anotherone I will check my router encryption setup, but I am sure it's correct, that's one thing I am confortable in doing... I will let you know if everything it's OK.
These are tonight stats:
Broadband Line Status
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:01:14:47
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 1376 Kbps 448 Kbps
Noise Margin 8.9 dB 13.0 dB
Line Attenuation 63.0 dB 31.5 dB
Output Power 16.2 dBm 12.3 dBm
Before I forget, I am back to te test socket, and I will give the i-plate a chance when I get to the source of my problems.
Re: My Opinion
06-05-2009 10:24 PM
Re: My Opinion
06-05-2009 10:29 PM
Re: My Opinion
06-05-2009 10:38 PM
Have you looked at the choice of wireless channels?
Re: My Opinion
06-05-2009 10:46 PM
