More ADSL problems
Nigel60
Re: More ADSL problems
HI,
BT engineer has been and says the line is now clear. Could you please reset my IP profile.
Pettitto
Fixes: 5
I can see that this has been done by the Faults Team now and everything appears to be back to normal.
Please let us know if we can help any further.
Nigel60
Was running stable for a week then rained, and dropping has started again. The BT engineer left his number and said contact him if there were any problems (he wasn't sure the line was really fixed). I will try and contact him first but maybe back if he can't help!  Angry
Nigel60
Ticket  #81845989 updated too! Sad
Nigel60
Just a quick update. The BT engineer is hoping to get round to me this afternoon (Monday) Smiley
Nigel60
BT carried out further work on my line yesterday (24/03/2014), remade the connections on the external pole.
Would it be possible for you to do a line reset, so that we can check the fault has now been rectified.
The drop in connection at about 3.30am 25/03/2014 was due to me.
Regards
Nigel Wilson
Pettitto
Fixes: 5
I've reset the lien for you. Your Speed Profile will update automatically shortly.
Nigel60
BT side ok but Plusnet profile is stil stuck at 0.3mb
Router stats
Operational Mode ADSL2+
Upstream 443
Downstream 10371
SNR Margin(Upstream) 28.9
SNR Margin(Downstream) 6.3
Line Attenuation(Upstream) 20.4
Line Attenuation(Downstream) 38.5
BT speedtest
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download  Speed
0.3 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.3 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 9.15 Mbps
Upload Speed
0.37 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Pettitto
Fixes: 5
I've just updated that for you.
You may need to log into your router and press the 'Disconnect' and then the 'Connect' button for the changes to take effect.
Nigel60
Thanks Chris,
Download speed now 8.55mb, let's hope this is the end of the problems. Upload is still slow(0.39mb) for an uncapped line, but I can live with that.
Jaggies
Your upstream is not uncapped:
Upstream 443
Nigel60
My upload is supposed to be uncapped, and was prior to the latest reset. If it has been reset to capped could you please remove the cap again.
Nigel60
Now that my connection seems stable, could someone please check that my upload speed is still uncapped. I was getting about 1mb up before the problems, now only 443kb!
Pettitto
Fixes: 5
Your line is currently still in the 10 day stabilisation period.
We'll be able to get your upload speeds sorted on 04/04/2014 when this ends.
Nigel60
I would like to thank all the staff at Plusnet, working as a team with BT Openreach and me, we seem to have got a result. My connection has been up for 24hours with no problems  Smiley
Router stats
Upstream 443
Downstream 10715
SNR Margin(Upstream) 26.3
SNR Margin(Downstream) 5.0
Line Attenuation(Upstream) 20.3
Line Attenuation(Downstream) 38.0
