turn on suggestions
FTTC Slow upload speed - capped?
- FTTC Slow upload speed - capped?
06-04-2014 9:11 PM
I'm on FTTC, I know I'm a long way from the cab, but I'm only getting 700kbs upload speed - yet the BT modem reports 18db SNR on the upstream.
Would this indicate my upstream has been capped in some way?
Re: FTTC Slow upload speed - capped?
06-04-2014 9:13 PM
Is that the reported sync speed or the results from a speed test
06-04-2014 9:17 PM
Quote from: Oldjim Is that the reported sync speed or the results from a speed test
Speed and SNR reported by the unlocked HG612.
06-04-2014 9:18 PM
what are the downstream speeds and noise margin
06-04-2014 9:27 PM
16Mbs and around 6db.
06-04-2014 9:35 PM
So that is around 2km from the cabinet
From this http://www.ispreview.co.uk/index.php/2012/12/when-slow-speeds-become-a-fault-on-bts-fttc-superfast-b... and knowing that you would be on the 40/10 option then the upstream speed should not be less than 22.5% of 16Mbps or 3.6Mbps
I suggest raising a fault at https://faults.plus.net
07-04-2014 12:31 PM
I can see that you've raised a fault with us. We'll get back in touch with you as soon as e can with an update for you.
Chris Pettitt
Cloud Environments Engineer
