Low speed!! On Unlimited fibre 80/20
- Re: Low speed!! On Unlimited fibre 80/20
- « Previous
- Next »
01-03-2013 9:34 PM
Quote from: AzureScorch I'm back to 70Mbps, changing gateway seemed to do the trick (restart router and maybe the BTopenreach modem too).
I'm on ptw-ag02 now, not sure which one I was using before.
It's really a bad idea to restart the router and modem - that may well cause your profile to drop. Just 'Disconnect' from the router webpage http://192.168.1.254/cgi/b/is/_pppoe_/dt/?be=0&l0=2&l1=2&name=Internet
01-03-2013 9:38 PM
Quote from: shalom2010
Thanks for the heads up.
I thought I recalled reading about that but I wasn't sure, I don't think the odd/rare restart does any harm though. I think if it happens often then the network presumes you're dropping out because your line can't handle the bandwidth (correct me if I'm wrong, I know very little about how a WAN works).
01-03-2013 9:40 PM
Jamie
01-03-2013 10:04 PM
02-03-2013 12:02 AM
Quote from: Anotherone The odd/rare restart of the BT Modem on Fibre can sometimes have major consequences, it's best avoided. Fibre DLM can be very aggressive at times.
Dont I know it....almost 10.5 MB drop...Hopefully the DLM will put it back up again..
06-03-2013 8:06 PM
Here's the speedtest of my slow connection
Jamie
06-03-2013 8:14 PM
Click here to see result!
Jamie
11-03-2013 4:15 PM
13-03-2013 5:49 PM
13-03-2013 7:11 PM
Oh well guess they'll fix it sometime before new year.
13-03-2013 7:18 PM
@darklight
I trust you are logging in to the router and dropping the PPP session and not touching/rebooting the BT modem
13-03-2013 7:29 PM
dick:quote
14-03-2013 6:02 AM
Quote from: Anotherone Jamie, you forgot to say which Gateway you are on, and Dave (or anyone else may not see that here, better to post that over on http://community.plus.net/forum/index.php/topic,111170.896/topicseen.html
@darklight
Don't Worry, I PM'd Dave, as Chris suggested via PM.
Jamie
- « Previous
- Next »
