Low speed!! On Unlimited fibre 80/20
- Low speed!! On Unlimited fibre 80/20
Re: Low speed!! On Unlimited fibre 80/20
28-02-2013 7:48 AM
28-02-2013 8:05 AM
Has this been happening much then? First time I've really noticed as I tend to browse on my phone in front of the TV in the evenings
28-02-2013 11:24 AM
Quote from: yorkiepudd Has this been happening much then?
Last 2-3 weeks. More people have noticed it in the past week or so though.
28-02-2013 12:36 PM
Quote from: englishrick It comes to us all Jamie......MY IP Profile has been reduced just because i changed a cable....god knows what will happen to the ip when we all start getting power cuts as they predict for the near future
What's that ! - you say the speed went down just because you changed a cable ?
Imagine what might happen if you did this - http://community.plus.net/forum/index.php/topic,112439
Does the name look familiar ?
Quote from: JamieDanjoux Yes plusnet, we demand answers, or will report to Ofcom.
And they will report you to BT !
28-02-2013 12:48 PM
Quote from: AndyH
Yeah well I have noticed a few problems recently, the 'main' desktop pc seems really laggy in the evenings, but put it down to the pc as the FTTC connection has been great since we got it (despite the fact that we were syncing at 68Megs to start with which dropped significantly thanks to router problems and never went back up, but hey, 40Megs is great compared to my old DSL 8))
28-02-2013 12:52 PM
Quote from: purleigh
Slow speeds were happening way before I changed the cable mate!!!!
28-02-2013 1:00 PM
Sorry if you took that the wrong way, my comment was only aimed at Jamie, and not at you at all.
I don't doubt that changing cables can have a significant impact on connection speeds.
On my own 20CN up to 8Mb ADSL line, my speeds improved just changing the router cable from the standard 1.5M lead to a 50cm one !
I just wanted to highlight to readers of this thread, that there might be other issues going on here in relation to Jamie's connection.
28-02-2013 1:56 PM
Quote from: JamieDanjoux Now one of the reasons I shouldn't have moved to PN Fibre and should have chose BT infinity instead!
Quote from: JamieDanjoux Welcome onboard the PlusNet nightmare!!!
Well, sorry to have to inform you Jamie, that Plusnet customers aren't the only ones suffering this problem. Have you not looked around the BT Community Care forums
I wonder if it has anything to do with rewiring the
28-02-2013 2:03 PM
Quote from: Anotherone Well, sorry to have to inform you Jamie, that Plusnet customers aren't the only ones suffering this problem.
Probably not, but he has been trying to - http://community.plus.net/forum/index.php/topic,112353
28-02-2013 2:12 PM
Quote from: englishrick I did have ip pofile of 77.43
Did you check the cable and follow the advice I gave at http://community.plus.net/forum/index.php/topic,112471.msg964572.html#msg964572
28-02-2013 7:54 PM
28th February 2013 19:52:49 Up - 6946 Kbps Down - 1698 Kbps
28-02-2013 8:56 PM
28-02-2013 10:01 PM
Actually, I haven't made any changes to my wiring yet, and the wiring is not the cause of the slow speeds otherwise I wouldn't achieve 60meg in the normal times, so just be quiet!!
Jamie
28-02-2013 10:04 PM
Quote from: Anotherone I presume you are aware of the Network issues affecting Latency and Speed for some, http://community.plus.net/forum/index.php/topic,111170.448.html is the current page in the thread covering the issue. There now also a Service Status. HTH (as far as info. goes)!
No I wasn't so thanks for the info
28-02-2013 10:05 PM
J
