Line speed
g0uex
Line speed
My line speed has dropped from 78Mb to 44Mb could someone have a look for me please.
The BT test reports IP Profile for your line is - 38.07 Mbps
g0uex
Re: Line speed
Could somone from plusnet have a look and see what the problem is?
Fixes: 62
Re: Line speed
Assuming your estimated speed is much higher than that I suggest raising a fault at http://faults.plus.net.
David
g0uex
Re: Line speed
Thanks for the reply.  My estimated speed is 66Mb, i am trying to use the fault system at the moment but it keeps hanging.
Re: Line speed
Hi g0uex,
I've responded to your ticket, we just need to see the results of a PPPoE connection, I've explained how to do this in the ticket.
g0uex
Re: Line speed
Hi Chris.
I have done as you requested and i have given the results over the phone.
g0uex
Re: Line speed
This problem is still ongoing though the linespeed is increasing in stages. I have just basically been called a liar on the phone and was told my line does not support the speeds i have been getting for the last 8 months or so.
It appears i am now back at square one for another raft of tests and false information.
Re: Line speed
This is currently with our faults team who are investigating, they'll update you as soon as they can.
g0uex
Re: Line speed
Thanks for the update.
g0uex
Re: Line speed
My linespeed is now back to around where it started and it appears i was not lying afterall.  Wink
Estimated line speed:61Mb (Accurate to within +/- 1Mbit) - Checked on 2013-01-03 01:40:18
Current line speed: 77.4 Mb
Fixes: 21
Re: Line speed
Quote from: g0uex
I hope the agent concerned will be given some "training"  Roll eyes
