Line reset
FIXEDTopic Options
- Re: Line reset
07-02-2023 11:03 AM - edited 07-02-2023 11:05 AM
Hello, I have conducted fault finding over several weeks and eventually solved the problem of network dropping, Forum members offered advice which helped. I posted back as promised and said the Openreach socket was the problem, unfortunately over the months my line speed has dropped to 73mbps and has not moved back up yet, could my line be reset please as I asked for this in the original post or do I have phone technical service.
Regards jono
Regards jono
Fixed! Go to the fix.
Message 1 of 6
(1,578 Views)
5 REPLIES 5
Re: Line reset
07-02-2023 7:33 PM
Message 2 of 6
(1,540 Views)
Re: Line reset
07-02-2023 7:40 PM
Thanks I will.
Regards
Jono
Regards
Jono
Message 3 of 6
(1,534 Views)
Re: Line reset
08-02-2023 1:51 PM
Hi Will Cutforth, your help is appreciated, could I ask if I need to reboot my router? I dont want to mess thing up so thought I'd ask first.
Router syncing at 80mbps down 20 mbps up.
Regards
Jono
Regards
Jono
Message 4 of 6
(1,494 Views)
Re: Line reset
08-02-2023 2:14 PM
@jono The router has resynced when the reset was done, it's back to full speed now so no need to do anything.😃
Message 5 of 6
(1,484 Views)
08-02-2023 2:59 PM
Thank you, pleased I didn't reboot.
Thanks to everyone who replied and gave me advice.
Regards
Jono
Regards
Jono
Message 6 of 6
(1,467 Views)
